Built in aperture adapter. at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old January 6th, 2013, 10:42 AM   #1
Going to order a metabones EF adapter soon. But first I'd like to ask if anyone has used an adapter with built in aperture. I don't really like the iris control wheel on the fs700.
In my opinion the upsides are
1 Lower price
2 same bokeh look for all lenses
3 easy control of aperture without the iris wheel
the downside is that there's no IS of course.
What are your opinions?
Sergiu Macarescu is offline   Reply With Quote
Old January 6th, 2013, 11:36 AM   #2
Re: Built in aperture adapter.
If you search around and read some on the subject you'll see that vignetting and softening of the image are common themes with those devices. I would recommend against one if you want to maintain image quality.
http://www.LandYachtMedia.com
Old January 6th, 2013, 06:24 PM   #3
I've heard something about vignetting, but didn't know about image softening.
Thanks for the quick reply.
Old January 7th, 2013, 10:43 AM   #4
I have the MTF adaptor for Nikkor (G) to e-mount, and the 16x9 Nikkor G to EOS.
Both exhibit very, VERY short throws on the iris control. 30 degrees from wide open to closed. You can lose a stop or two brushing past it to find the focus ring if you're concentrating on the shot. If you keep it loose, you could probably knock half a stop just by blowing on it. I prefer to stick to Canon EOS lenses with the Metabones adaptor and the iris control on the body. And I get IS.
EX1 x2, C100 --> FCPX & PPro6
Old January 7th, 2013, 09:11 PM   #5
The metabones (and others) adaptors that have built in mechanical iris rings are very poor solutions. The iris is in entirely the wrong part of the optical path and as a result leads to vignetting.
A compromise solution if you don't like using the iris wheel is to use the metabones electronic adapter to control the lens iris for course exposure control and then us a variable ND flyer for fine control. Of course you could also look into lenses with manual iris rings like the Samyang/Rokinon lenses that even with the Canon EF mount still have proper manual iris control.
Old January 9th, 2013, 04:19 PM   #6
Thats my next puchase Alister' could i ask you a question just something i just can't quite get my head around, when i watch vemio and you tube fs700 super slow mo the clips may go from normal speed to super slow or visiversa or fast motion to slow motion without stopping i can do it in post but how do you do it in camera doing it in post its not the same. Thanks Wilf Davies.
Wilf Davies is offline   Reply With Quote
Old January 9th, 2013, 04:25 PM   #7
You can't do speed ramps in camera. That is an effect to perform in the edit room.
Old January 9th, 2013, 04:36 PM   #8
Thats what i thaught but i was'nt sure if i was doing something wrong.Thanks very much for that Wilf.
