fs100-by swapping gain & iso i can now store 6 presets!
this might be obvious to others but wasn't to me until this morning, so i apologize in advance. under the camera menu, we have the opportunity to select gain or iso. i usually do gain and select 0 +6 +9 i was fiddling with the iso select option and put in 500 1600 3200 when i toggled back and forth between the select gain/iso, i realized that the 0 gain and 500 iso were the same (obviously!). then why store both? i could use the gain to increase the light by smaller increments 0 +6 +9 and i could use iso for the bigger jumps when needed 1600 2400 3200 i can now store six presents rather than three. well, live and learn! i still find the fs100 to a rock solid indoor interview camera. ymmv be well. rob smalltalk productions/nyc |
Re: fs100-by swapping gain & iso i can now store 6 presets!
Good to know. Thanks for sharing. I do wish there was a dedicated ISO or Gain dial (or at least a 2-button solution). But this helps.
I agree about this being a great interview cam. I'd love to know what your go-to lighting kit is. |
In both cases, it's a pity that the lowest ISO is 500. On any Sony stills camera they go as low as 100 ISO. A shame these lower settings are not available on the FS100…
Contributor
I agree--I use an ND filter even for many indoor shots.
#5 |
Rob thanks for the info. I made a chart so I could test the different settings to get the most out of the six available presets. I do interviews with b-roll and a lot of the time the b-roll is very run and gun. So it may take me a while to figure out what is the best walk around settings but this is what I am starting with.
