Interview microphone for the FS100? at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old July 19th, 2012, 07:21 AM   #1
I've used a Beyerdynamic M 58 ENG interview microphone on a shoot with the FS100, but the audio level was very low. I had to set the audio levels to (almost) max, to at least get some audio from it.
Can anyone recommend me a better interview microphone for the FS100?
Derran Rootring is offline   Reply With Quote
Old July 19th, 2012, 07:47 AM   #2
Re: Interview microphone for the FS100?
That is a dynamic mic and needs a different mic trim than an electret mic (the stock mic).
Check out page 36 of the FS100 manual to see how to change the mic trim in the menu.
http://www.LandYachtMedia.com
Old July 19th, 2012, 08:23 AM   #3
Thanks Chris, will have a look at it!
Old July 19th, 2012, 12:25 PM   #4
Look out for the Triton Audio 'FEThead' microphone pre-amplifier:
FetHead - tritonaudio
Basically, you plug it into the mic input, it gets power from the camera's Phantom Power, and this drives a relatively high quality amplifier that cleanly raises your microphone level by +18dB.
Of course, dynamic mics don't requrie phantom power, but because they generate their own juice - at low level as you've discovered - they need a little help. But not all 'microphone pre-amplifiers' are built the same. I love my Sound Devices stuff now, but the FEThead helped a lot before.
EX1 x2, C100 --> FCPX & PPro6
Old July 19th, 2012, 04:25 PM   #5
That's a great tip Matt. Seems like a very handy amplifier!
I looked at the manual and was able to boost the mic level to +12 and that was enough to get proper sound from it! So, problem solved. :) Thanks for the help guys.
Old July 19th, 2012, 05:22 PM   #6
Just remember to set it back before plugging in a "hot" mic. Otherwise you'll have a ton of distortion.
Glad we could help.
Chris Medico is offline   Reply
