Fs100/nx5u at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old July 1st, 2012, 03:24 PM   #1
Fs100/nx5u
I just purchased a FS100 to replace one of my NX5s...does anyone by chance use both and what would I expect I need to do when I have to use both cams and try to match as best as possible...
Should I expect I will need to setup a PP on the 100?
Thanks in advance....
Mark A. Foley is offline   Reply With Quote
Old July 2nd, 2012, 05:32 AM   #2
Re: Fs100/nx5u
Mark,
I bought the fs100 first then the nx5. We shoot quite often with both. If you use the same pp and same color temp ( I always use Kelvin so they match), they cut really well together. The nx5 does suffer in low light, but Dan asseff on this forum just boought a $100 program that does wonders in clening up the grain on low light footage.
I'm happy with bothm although the fs100 is challenging ergonomically for quick, run and gun type shooting.
Bruce Yarock
Yarock Productions
btw, did I buy some camera hard drives from you sveral years ago?
Bruce S. Yarock is offline   Reply With Quote
Old July 2nd, 2012, 05:35 AM   #3
Re: Fs100/nx5u
Thanks for the response Bruce...and yes I believe I did pass some cam hard drives on to you.
