red pixels at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old January 8th, 2012, 06:34 AM   #1
red pixels
I did a timelapse of the sky last night @18db and 1/3 second. In the footage there are two clear red pixels, that I do not see under 'normal' shooting circumstances. Also not when shooting (very) dark scenes. Does someone know where this comes from and what to do about it?
Cees van Kempen is offline   Reply With Quote
Old January 8th, 2012, 12:01 PM   #2
Re: red pixels
I recall from my trv 900 days that under these circumstances - high gain and low shutter speed at 24p - hot pixels on the sensor that don't show up under normal shooting specs can show up. That might be the case. It was a serviceable issue, as I recall, though this was long ago.
www.stusiegal.com
Stu Siegal is offline   Reply With Quote
Old January 8th, 2012, 12:53 PM   #3
Re: red pixels
It is possibly dust on the sensor. I already had that issue but was easily fixed.
Keith Forman is offline   Reply With Quote
Old January 8th, 2012, 03:32 PM   #4
Re: red pixels
You could try black balancing. Sometimes recovers lost or stuck pixels.
Ryan Creason is offline   Reply With Quote
Old January 12th, 2012, 05:12 AM   #5
Space Hipster
Re: red pixels
Someone on another forum had this same issue. Black balancing should correct this.
Old January 13th, 2012, 01:55 PM   #6
Re: red pixels
Thanks all. Black balance did the trick. What worries me however is the remark in the manual: "The adjusted settings are stored only temporarily. The settings return to the default settings when you turn the power off."
I did not see the red pixels reappear after switching on/off, but does this risk exist?
