HDMI to SDI adaptor? at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old December 10th, 2011, 12:10 PM   #1
A producer I do some work with wants to do a multi camlive streaming concert in HD. I've done a few before with the FS100 using an adaptor from the composit out to bnc, both iwred and wireless. But for HD, obviously, you have to come out of the hdmi.
The least expensive thing I see is the Black magic.
Anything else around?
Bruce Yarock
Bruce S. Yarock is offline   Reply With Quote
Old December 10th, 2011, 12:50 PM   #2
Re: HDMI to SDI adaptor?
AJA also makes one but its a little more expensive.
http://www.LandYachtMedia.com
Old December 10th, 2011, 06:09 PM   #3
Bruce Yarock
Amazon.com: Blackmagic Design HDMI to SDI Converter: Electronics
The black magic is probably going to be the cheapest option. I use one on a regular basis, an I like it a lot.
Michael Beck is offline   Reply With Quote
Old December 11th, 2011, 12:39 AM   #4
Thanks for the info, Michael. How do you have it attached to the camera? Picture?
Bruce Yarock
Old December 11th, 2011, 02:26 AM   #5
I was going to Suggest the Atomos Connect as its more portable and is designed to be able to run off battery power (Standard Sony NP Batteries at that), unlike the Blackmagic, However it is still showing Coming Soon, so will probably not work if you need it soon.
Having Said that, if you event is still a ways off, You could wait for this as while it is s little more expensive(USD 350), it does look a much better fit with your FS100 the juryrigging the Blackmagic Adaptor with Batteries, or being tied down to external power for the event
For More Info - Atomos Connect Converters
Brochure - http://atomos.com/connect/media/conn...A4-IBC-web.pdf
Video - IBC 2011: ATOMOS Connect - versatile onboard hdmi to and from SDI converters 249? - YouTube
Baiju Gadhia is offline   Reply
