Adjusting gain at DVinfo.net
Sony NXCAM NEX-FS100 CineAlta
Old November 15th, 2011, 09:34 PM   #1
Adjusting gain
If this is possible, I haven't figured it out Any way to adjust gain, other then the 3 way selector switch? I'd love to be able to scroll through the different gain settings by dialing the wheel. Kind of a pain to have to go into the menu and assign the high, medium, and low values.
Jeff
Jeff Troiano is offline   Reply With Quote
Old November 15th, 2011, 10:57 PM   #2
Re: Adjusting gain
Currently that's the only way to do it. You can set the gain to auto mode and it will float. Useful in certain circumstances.
John Mastrogiacomo is offline   Reply With Quote
Old November 15th, 2011, 11:36 PM   #3
Re: Adjusting gain
Sony should be able to do it with a firmware change, but will they and when?
Galen Rath is offline   Reply With Quote
Old November 16th, 2011, 12:02 AM   #4
Re: Adjusting gain
I emailed and asked them to add more frame rate control in S&Q. They replied back that it was difficult to do in an AVCHD camera, but there engineers were looking into it. They also said that was a request they've gotten a lot for. I should have asked for better gain control also..lol
Old November 17th, 2011, 06:09 AM   #5
Contributor
Re: Adjusting gain
I guess with traditional video cameras we've only flicked in gain when wide open and not enough light. The FS100 with it's hi ISO ability changes the paradigm a bit so that requests like this make a lot of sense.
Auto ISO might be a good enough option though, especially if the camera meters accurately or even consistently so you can offset it with exposure compensation (AE).
John Mitchell is offline   Reply With Quote
Old November 22nd, 2011, 06:11 PM   #6
Re: Adjusting gain
Almost all Sony cameras including the top professional models will only give you a choice of three gain settings at a time, and all are selectable in the menu. This is common for other brands, as well.
Chuck Fishbein is offline   Reply With Quote
Old November 22nd, 2011, 06:51 PM   #7
Re: Adjusting gain
It's always been the standard way of doing it on ENG cameras, but the gain have never been so usefull than on today noise-free large sensor cameras. The best implementation of gain I ever seen is on CANON XL serie of cameras. The physical switch on the body alowed any gain setting from -3 to + 18 is 3db step, plus a button and a wheel to manually select any gain setting in 0.5db increment. Nice!
On the FS100, in the menu you can top the auto gain setting to 0 db. This way the gain button is your 0 db setting, and you can set 3 other values on the switch.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old November 23rd, 2011, 11:54 AM   #8
Re: Adjusting gain
j-p-
that is an interesting thought.
thanks for sharing.
be well
rob
smalltalk productions
Rob Katz is offline   Reply
