Sony AX2000 LCD issue on overlay text - RED color under white text at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old July 12th, 2014, 08:23 AM   #1
Well, after 4 years of soft use the AX2000 shows this issue, on LCD screen and visor: RED shawdows under overlay texts & graphics.
It don't affects recordings, but it's a bad signal. Let's wait to see what happens.
yfrog Photo : http://twitter.yfrog.com/nciy6gj Shared by
yfrog Photo : http://twitter.yfrog.com/mubwc4j Shared by
yfrog Photo : http://twitter.yfrog.com/nlew8uj Shared by
yfrog Photo : http://twitter.yfrog.com/ms99dej Shared by
Now I'm using a new Canon XA20 (yes, the mames are vey similar) and I am very surprised by the quality, use and performance.
More recording options (1080 50p, etc.), wifi remote (quite useful), more image definition (the AX2000 is more or less a quite good 720p sensor, not FULL HD), less noise and very very similar in luminosity (one stop abowe????, I can't mesure it but is nearly the same in real conditions recording the same in dual carmera mode).
I can combine the two seamlessly if I render the final output to 720p. If I mix together to a 1080p render the AX2000 shows less definition, quite noticeable.
Then is better to use the AX2000 for closeups and the XA20 for wide shots.
Mikel Arturo is offline   Reply With Quote
Old August 14th, 2014, 02:19 PM   #2
Re: Sony AX2000 LCD issue on overlay text - RED color under white text
It gets worse. :(
<a href="http://imgur.com/KlEpSJT"><img src="http://i.imgur.com/KlEpSJT.jpg" title="Hosted by imgur.com" /></a>
imgur: the simple image sharer
