Sony AX2000 rec only on one memory stick only at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old June 4th, 2012, 02:37 AM   #1
Hi, may be do I have to configure my Sony AX2000? Some days ago it recorded on two memory sticks but now AX2000 records on only memory stick. That is when the memory stick is full, AX2000 doesn't go to record to second memory stick automatically. Thanks for some info.
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos
Adriano Moroni is offline   Reply With Quote
Old June 5th, 2012, 11:37 AM   #2
Re: Sony AX2000 rec only on one memory stick only
The AX will record continious from A to B, but not from B to A. So just make sure you start on A.
Ben
Ben Moore is offline   Reply
