Noise when writing to card and flash drive - Page 2 at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old February 8th, 2012, 02:43 PM   #16
Re: Noise when writing to card and flash drive
The ISOBLOX solved my problem on the FS-100, can now use battery powered mics without beeping .
Galen Rath is offline   Reply With Quote
Old February 10th, 2012, 08:05 AM   #17
Galen,
After all of the help I have received here on the forum I am glad I could finally help someone else.
David Allen is offline   Reply With Quote
Old February 19th, 2012, 12:31 PM   #18
I am back from my holiday and have tested my NX5U with my AKG C1000S that can be battery powered as well as 48Volts. I have no noise in either mode when selections are set to 48Volt on the NX5U for phantom power and to just mic when on battery power. This for FMU128 and SD card , just FMU128 or just SD card. SD card is a Patriot LX 32G Class 10 card. All were done with Sony mic on phantom 48Volts Channel 1 with the C1000s being switched between battery and 48Volt supply on Channel 2.
Ron Evans
Ron Evans is offline   Reply
