#16 |
Re: What NLE's are NX70 shooters using?
I have only shot 1080 60i so far. But does SVP change the footage from interlaced to progressive during the downscaling, then bring back as an interlaced file?
#17 |
Unless you want very long times with small cards then shoot at 24Mbps. I shoot all my CX700 at 60P which is 28Mbps. Just make sure the project settings match the files.
You got the sequence correct but if you just want to check T5 there is no need to use Vegas at all. My sequence would be to use Content Mangement Utility to transfer files to PC. Open these file(s) in T5 do some editing. It is simple but will do cuts and add text etc. Then encode for DVD. Use these files in DVDA. I thought you would like to see the difference between exporting from Vegas and T5 simply. This is simplest way using the same short file. Ron Evans |
#18 |
Ron,
My early experiments with TMPGenc look promising. Thanks so much! In the future I plan to edit with SVP but I think I'll do all my HD>SD DVD encoding with TMPGenc. Eric |
#19 |
I edit mainly with Edius but encode with T4 as the best downconvert/encode for me. I export a Canopus HQ fine file from Edius then encode in T4, author in DVDA. Edius has a fast h264 export using the Quick Sync of the Z68/ i7 2600K processor I have so that is how I encode for Bluray. It will export a h264 timeline of 1 hour and 45 mins in 40mins.
Ron Evans |
