Video, including after dark at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old August 19th, 2011, 06:13 PM   #1
I put a few clips together, including some when it was quite dark. The 70U is a lot easier to use than the EX1R for this kind of video because of its great image stabilization. I used Premiere 5.5, which I am still trying to learn, because (unlike with FCP), I can import the files without converting them first. I do wish the camera had a build in ND filter. A wider selection of WB presets would be nice too.
Bill Hollinger is offline   Reply With Quote
Old August 27th, 2011, 09:50 AM   #2
Re: Video, including after dark
Did you use your own external NC filter of the bright daylight images? I don't see much of the choppy artifact caused by using higher shutter speeds.
Chuck Fishbein is offline   Reply With Quote
Old August 27th, 2011, 04:19 PM   #3
I used the ND filter Sony sells as an accessory for the camera,
http://www.bhphotovideo.com/c/product/671714-REG/Sony_VF37NKB_VF_37NKB_Filter_Kit.html
