Shoulder Mount at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old May 14th, 2011, 06:42 PM   #1
Shoulder Mount
What is a good shoulder mount for the NX5u without breaking the bank?
Chris Sgaraglino
The Outdoor Life Blog | Widow Creek Photography
Chris Sgaraglino is offline   Reply With Quote
Old May 16th, 2011, 07:10 AM   #2
Re: Shoulder Mount
Have you looked at the spiderbrace 2....
http://www.spiderbrace.com/
I use it with my AX2000, lightweight and works great, and it does not break the bank...
David Wayne Groves is offline   Reply With Quote
Old May 16th, 2011, 10:06 AM   #3
Re: Shoulder Mount
I have looked at a couple in this configuration, the issue with these kind of braces is that with your hands on the two (or even one) handle - that hand is not available for controlling the camera?
Chris Sgaraglino
Old May 16th, 2011, 10:23 AM   #4
Re: Shoulder Mount
That's the problem with any camera like this; there's really nothing you can do to make it like a shoulder-mount cam. There are some shoulder braces that have controls on them that attach via LANC and replace the controls on the cam, as far as I know, but it isn't the same.
However, there was one shoulder brace I used that had a terrific counter balance that dropped behind your shoulder, almost halfway down your back. You could even remove your hands completely and the cam and brace would just balance neutrally. Your right hand stayed on the cam's handgrip when you shot. As I recall it was called the CB-105 and it was available on eBay from someplace in California. No idea if it is still available but might be worth a search.
Edit: There are actually several threads on this in the Shoulder Mounts subforum, including links to the site where they sell these. Here's one:
http://www.dvinfo.net/forum/shoulder...der-mount.html
Old May 21st, 2011, 07:25 PM   #5
Re: Shoulder Mount
Chris here is my mount. I made it more like a shoulder mount. It is kind of a Frankenstein mount. I took some parts from my DV rig to take the weight off.
Dan Asseff is offline   Reply With Quote
Old May 21st, 2011, 07:34 PM   #6
Re: Shoulder Mount
Dan,
How much did that whole rig cost you? can you include a link where you purchased the shoulder mount?
Mike
Mike Butir is offline   Reply With Quote
Old May 21st, 2011, 07:51 PM   #7
Re: Shoulder Mount
Mike, If you don't count the DV rig (cost $300.00 off ebay) Just under $700. Here is a used matte box in in the classified.http://www.dvinfo.net/forum/private-...ff-system.html Just add the hoodloop got mine here and he made it work better for the NX5 HoodLoop
Here is another post http://www.dvinfo.net/forum/sony-nxc...ystem-nx5.html
Dan
