Shot gun for AX2000 at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old September 18th, 2010, 02:17 PM   #1
Shot gun for AX2000
Will this mic fit in the mic holder on the AX2000?
Audio-Technica AT875 Short Condenser Shotgun Microphone AT875R -
I can't find the tube size specs?
Ben
Ben Moore is offline   Reply With Quote
Old September 19th, 2010, 03:01 AM   #2
Audio-Technica's AT875R dimensions: 175.0 mm (6.89") long, 21.0 mm (0.83") diameter.
Arkady Bolotin is offline   Reply With Quote
Old September 19th, 2010, 08:02 AM   #3
Thanks Arkady!
Ben
Old September 20th, 2010, 08:15 AM   #4
Has anyone tried mounting this mic in the AX2000 or NXCam?. I measured the distance inside the mic holder and its a close weather this mic will fit, the outter dimmensions of the mic @ 21mm may be to small for the holder.
Thanks for any input
Ben
Old September 21st, 2010, 02:44 PM   #5
I use the Rode NTG-1 Shotgun Mic with my Ax2000, I slipped on a few rubber O rings and it now works perfectly.....
David Wayne Groves is offline   Reply With Quote
Old September 28th, 2010, 02:42 PM   #6
Thanks David, I ended up getting the AT875 and doing the same thing, works great FWIW.
Ben
