How to get more detail/crisper picture with NX5 at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old June 18th, 2010, 09:58 AM   #1
Has anyone have any tips on getting a more crisp image with their nx5.
Thanks in advance.
Andy Loos is offline   Reply With Quote
Old June 18th, 2010, 01:34 PM   #2
here's one setting to try...
I've done some experimenting with the detail settings and I found there was a noticeable difference with this Picture Profile setting as regards to sharpness.
Set detail to +4
Set v/h balance to -1
Compare your sharpness with a before and after test and on a good large size high resolution screen you should see improved sharpness.
I have also been experimenting with the Picture Profile color modes and will have some settings to post on that later...the goal being to get a slightly warmer, more accurate color look.
John
John Vasey is offline   Reply With Quote
Old June 19th, 2010, 07:10 AM   #3
awesome, thanks John.
Old June 21st, 2010, 09:13 AM   #4
John - what do you mean by "v/h balance"? thnx :)
Dave Luda is offline   Reply With Quote
Old June 21st, 2010, 03:14 PM   #5
v/h balance
The v/h balance helps define the width of the edge that separates areas of contrast...the tradeoff being that you don't want to get the width too large or it will have a halo effect around the edge. But a slight increase in width will achieve more perceived sharpness. A "negative" number in the v/h settings, contrary to logic, actually helps achieve this.
I don't profess to be an expert on all the technical nuances of the detail settings...but I did learn that the v/h balance plays a significant role in edge sharpness under the larger global control of the detail adjustment. It's best to think of v/h as defining the width of the edge and then a positive detail setting further amplifying the effect of it.
You can certainly try out permutations of it and see what works best for you! John
