Camera metadata information at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old May 30th, 2010, 04:13 PM   #1
What menu option do I have to select in order to find the following?
- Firmware installed on the camera;
- Current setup (including customized selection);
- # of recording hours don with the camera...
Thanks in advance!
Daniel Paquin
Production ZoOM vidéo
Daniel Paquin is offline   Reply With Quote
Old June 4th, 2010, 07:25 PM   #2
Operation time is displayed in 10 hour increments in the OTHERS menu on the HXR-NX5U.
You can use the firmware updater software from Sony to check the current version of firmware on your camcorder. You can download the Firmware version 2 software update from Sony and follow ithe PDF of nstructions in the zip file (http://support.sonybiz.ca/esupport/e...xbUAw+awFrWBE=)
John McManimie is offline   Reply
