Display Settings at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old April 25th, 2010, 01:29 PM   #1
Display Settings
Does anyone know?
How to keep the time code zeros on upper right hand corner from being displayed on the camera LCD. I've been doing alot of live feeds lately and it seems that pressing the display button does the trick, but it also hide the remaining record time and battery life.
Abraham Texidor Sr. is offline   Reply With Quote
Old April 25th, 2010, 02:06 PM   #2
How do you have the output setup? Look on pages 53 and 84 of the manual. And do you have marker set on as this will just display timecode on output also on page 84. If you are feeding an output and don't want anything on this output then select LCD panel in the menu. "All output" will send whatever is on the display to all outputs. The display button cycles through from full display>simple display>no display.
Ron Evans
Old April 27th, 2010, 05:40 AM   #3
Thanks Ron
