I must vent about my day with the AX-2000 - Page 2 at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old April 11th, 2010, 06:52 PM   #16
MPS Digital Studios
Terrific, Sherri! It seems a lot of logging and transferring problems stem from PCM audio; I know I switched the camera I was reviewing immediately to Dolby, so I'd avoid any frustrations.
Heath
My Final Cut Pro X blog
Old April 13th, 2010, 04:54 PM   #17
low light issues
Hi Sherri, how is your AX2000 performing in low light? I just can't get a good clear picture. I am getting a lot of grain, even if I use a light, the background and some images even on the lighted areas have grain. I can't figure out how to get a good looking low light picture. I have seen footage online that looks great.
Daniel Casper is offline   Reply With Quote
Old April 13th, 2010, 05:10 PM   #18
Are you shooting in automatic? Do you have the gain limit set or are you leaving it go to 18db? I have NX5U but assume the settings are much the same. Try setting your gain limit to 12db and see if that produces a more acceptable picture for you.
Ron Evans
Old April 13th, 2010, 08:21 PM   #19
Hi Daniel,
I haven't had a low light situation with the camcorder yet. But I did set the gain control limits to 0 for L, +6 for M, and +12 for H. I leave the camera's gain control in the L setting so that I always start out with 0 gain when using it manually. Then I can up the gain as needed.
Follow me on Facebook!
http://www.facebook.com/TCPalmSherriNestico
Sherri Nestico is offline   Reply With Quote
Old April 16th, 2010, 12:16 PM   #20
Those aren't limits; they are the actual values in GAIN SET for when you use manual gain. Ron's talking about AGC LIMIT to set a maximum value the cam will add in Auto Gain mode. Entirely different. Both on p 69 of the AX2000 manual.
Old April 16th, 2010, 09:48 PM   #21
OK, I stand corrected.
