Sony VG900 - audio gap after 4GB limit - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old September 6th, 2014, 07:28 AM   #16
Re: Sony VG900 - audio gap after 4GB limit
If you have a card with all its contents and a card reader then you can use Vegas but DO NOT use the 'import media' dialogue. Depending on the version of Vegas you are using you can use the 'Device Explorer' under the 'View' menu or call up the Device Explorer using CTRL+ ALT+ 7. Under its dialogue select a destination folder and import all the clips. Spanned clips from long takes will be brought in and joined correctly as one long clip without audio breaks. Short clips that were stand alone takes will come in as short individual clips.
Chris Young
CYV Productions
Sydney
Chris got in before me !! The clips should appear in the right window and card in the left window.
Ron Evans
Old September 6th, 2014, 11:29 AM   #17
Ron and Chris,
Thank you both!
Using device explorer did the trick. It read the files from my USB bus powered drive and imported them as one unbroken clip. Makes things a whole lot easier next time.
Thanks again,
Ken
Ken Plotin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
