Anyone know... at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old January 4th, 2013, 10:01 PM   #1
Anyone know...
...If the VG20 can be used as a webcam? 'Cause it would be super sweet if it could.
John Vincent is offline   Reply With Quote
Old January 5th, 2013, 12:45 AM   #2
Re: Anyone know...
How are you thinking of hooking it up? HDMI? Component? It's probably overkill for a "webcam", but should be "possible" I would think, with the right input and software on the computer.
Old January 13th, 2013, 09:35 PM   #3
Re: Anyone know...
I'm just recording it, then putting it on a timeline. Not as easy, but what's ya gonna do?
Old January 14th, 2013, 03:26 PM   #4
Re: Anyone know...
With an Intensity Pro on the latest drivers and Xsplit, it is possible. The computer takes the Xsplit output as a webcam.
Old January 15th, 2013, 10:54 AM   #5
Re: Anyone know...
I'm using xsplit as we speak for the broadcast at (cheap plug)....
evilgeniusentertainment.com
I'll look into Intensity Pro - thanks for the tip!
Old February 5th, 2013, 11:42 PM   #6
Re: Anyone know...
Let me answer my own question:
Sometimes I forget that the VG20 has composite out. It's not super great quality, but it works.
I use an older "Dazzle" video breakout box which connect to my PC via a USB cable. I hook the 20's composite & audio cables into it and BAM! it records just fine. Before I was recording mu bumpers, then putting the car into a reader, then uploading it, then accessing it with Vegas.
So I save a couple of steps. BTW, you can see the end results at my "tv station" at:
evilgeniusentertanment.com
We're looking for original horror, scifi, or action flicks - full length or shorts.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
