Fast zoom lenses for the VG20 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old March 23rd, 2012, 02:02 PM   #1
I was using a Sony HVR-Z5E camcorder and noticed how easy, smooth and fast the zoom was using the manual ring and so was the focus.
My current SEL1855 Lens is not pleasant to use when zooming in or focusing, in fact its quite resistant and requires an effort to zoom or focus. I plan to replace this lens with a better one but I wanted to know if there's any good lenses that the zoom is extremely smooth and fast with little effort required, it doesn't have to be a SEL lens since there are many adapters for the E mount system.
Any recommendations would be appreciated
Chris Law is offline   Reply With Quote
Old March 23rd, 2012, 05:16 PM   #2
Re: Fast zoom lenses for the VG20
Chris,... just want to point out here that you have just discovered what many people don't realize when they move over to DSLRs from camcorders. Your SEL lens may be better or worse than average for photography lenses but photography lenses don't need the silky smooth zoom and focus rings that video does. Even my expensive Canon L lens can't hold a candle to any of my camcorder rings. This situation may change if lens makers start making lenses for DSLR video but don't expect them to be cheap photography lenses anymore. Good luck.
Old March 24th, 2012, 03:20 AM   #3
HDV Cinema
And, when mounting DSLR lenses -- as the iris changes they will do so in steps. No smooth adjustment.
Old March 24th, 2012, 04:13 AM   #4
It depends what your are filming. Try a different workstyle, maybe zooming in and out is a bit to much and
for Run and Gun may be ok.
I often u se 2 camcorders one static wide to narrow and the other with the closer framing. Sometimes with fixed lenses 1.8 50 mm or 2.0 100 mm Fokus on the important things.
"You are certainly free to choose fear if you want to. That's all part of The Illusion."
Werner Graf is offline   Reply With Quote
Old March 24th, 2012, 06:50 AM   #5
I recommend the use of a zoom or focus lever.
I use one similar to this
New Adjustable Flexible Gear Ring Belt for DSLR Follow Focus FF | eBay
I replaced the screw with a longer one 100mm M6
Its just like Super 8mm days!!!
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
