Battery compatibility: Type V and Type H at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old March 19th, 2012, 09:16 PM   #1
The manual specifies the Type V. Type H from an older camera looks identical. Both can be charged with the Type H dual charger and both read the same battery status. Both are Actiforce product line and both have the same capacity and voltage on the lable. Type H will not engage properly in the NEX VG 20. The center index tab on each side is 50% too long. Simple effort with a knife, chisel or Dremel tool would cure that. My question is, has any one done this or does anyone know why it won't work. My guess is the guts are identical, but Sony Marketing needs a change every couple of years to get us to throw out the older gear.
Terry Cummings is offline   Reply With Quote
Old March 20th, 2012, 03:05 AM   #2
Re: Battery compatibility: Type V and Type H
Hi Terry -
DOES NOT WORK... been there, tried it...
Sony changes the ICs in the bateries so they are NOT "forward compatible" (older battery won't work in newer cams). They also change the notches just enough that the older batteries don't fit physically, but since they know the knockoff batteries can change their molds faster than you and I can grab the Dremel or X-Acto... they recode the chips as well. Since knockoffs are a MAJOR problem, I think this is as much an attempt to stay ahead of the counterfeiters as anything... but it's annoying for the end user!
The older chargers still seem to work just fine, and don't have the physical "lockout" that the cameras do. Supposedly the "new" chargers ahve some features to take advantage of the "new" batteries, but I have my doubts, other than MAYBE faster charging...
Short of it is, if you're using current generation Sony cams, you need FV series batteries - which have been around about 2-3 years, so I'll not be surprised if there is a new F"x" battery soon...
Old March 20th, 2012, 11:54 AM   #3
Thanks for the insight. I'll put the older H batteries back in the shoe box.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
