What to Buy ? - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old March 17th, 2012, 11:07 PM   #16
HDV Cinema
Re: What to Buy ?
Originally Posted by John Vincent View Post
"NAB should be fun b/c we're going to start seeing the true death of 8 bit/4:2:0 camera tech, with 2-4K becoming more of a reality. Lot's of juicy tech will be coming down the pipe in the next year... all priced at a premium I'm sure.
I'm only posting about new tek because it's what coming and not because I expect to be able to afford it -- although the Digital Bolex is sort of affordable.
I'm not even sure I like the look typically applied -- so tired of green subways, blue NYC, and bleached white skin.
So far the best looking VIDEO -- I can afford -- comes from the NEX as well as the JVC 1080p60 at 36Mbps. BUT, they simply can't handle super contrast situations. Even if their sensors can capture 12-stops, squeezing data to only 8-bits is tough. Something has to give. Too prevent over-exposure I have to darken the total image way too much.
Of course, having an adjustable-knee helps along with black expand. Settings left out of the VG10/20.
Steve Mullen is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
