To Maui with the VG20 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old February 16th, 2012, 11:47 PM   #1
I took the VG20 to Maui for a friends wedding week. I was not official videographer, and I treated the camera and shooting like a tourists uses it- hand held most of the time...
http://vimeo.com/groups/115787/videos/36944213
Chris J. Barcellos
Old February 17th, 2012, 01:15 AM   #2
Re: To Maui with the VG20
Chris, looks great and you must of had loads of fun...
As pretty as the day footage was, I have to say that the night footage was even more impressive. Any particular tricks that you used to achieve the look?
John Vincent is offline   Reply With Quote
Old February 17th, 2012, 12:16 PM   #3
John:
For the night stuff, I shot with an old Nikon 35mm F 2.0. For the VG20 that would be considered a normal lens With no zoom, so I had to move back for wider shots. Wide open. I may not have switched from daylight to incadescent in the heat of the shooting (as well as being under the influence of wine and spirits).
Chris J. Barcellos
Old February 18th, 2012, 05:00 PM   #4
remove, posted in error
Chris J. Barcellos
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
