VG2O Questions Answered- Footage coming. - Page 6 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old November 9th, 2011, 03:37 PM   #76
Re: VG2O Questions Answered- Footage coming.
About the golf shot, I will review what I did this evening.
I am attaching a still lifted from my Vegas time line. You can tell I had to boost levels a lot to get what I got in the end.
Chris J. Barcellos
Old November 10th, 2011, 08:34 PM   #77
tonality, slo-mo, detail
Dislikes:
cinematone, moire on the roof tiles
Other:
blocking looks like youtube related artifact
Old November 16th, 2011, 09:42 AM   #78
could you answer a quick question that the inaccurate specs do not even bother to mention.
Does the composite video out work during shooting. The reason why I ask is that I have a classic Steadicam JR with a daylight viewable monochrome screen.
This appears to be a perfect match with the 16mm pancake lens for event work, if there is monitor out on composite.
I could forgive the shortcomings if this is possible.
Curtis Campsall is offline   Reply With Quote
Old November 16th, 2011, 11:15 AM   #79
Curtis:
I've had the component HDMI hooked up while shooting, but haven't done the component or composite thing. I will try to check it out later today.
Chris J. Barcellos
Old November 17th, 2011, 11:49 PM   #80
Curtis:
Good news. HDMI, Component video, and composite video all work during recording.
Chris J. Barcellos
Old November 18th, 2011, 08:43 AM   #81
Thanks for taking the time to test the line outs.
Old November 24th, 2011, 10:03 AM   #82
One point that needs to be made about the Manual dial:
All adjustments to exposure are in 1/3 stop intervals; it is not continuous. That means that on-the-fly adjustments are going to be visible in the footage. A further annoyance is that the VG10 has detents, so there's no hunting for the next 1/3 stop up or down.
I'll probably return the VG20, attractive as some of its features are. Quite disappointed.
Joel Crawford is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
