NEX-VG10 + nanoFlash at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
Interchangeable lens AVCHD camcorders using E-Mount lenses.
Old January 3rd, 2011, 03:33 PM   #1
Dear Friends,
We have a thread going in our nanoFlash forum.
http://www.dvinfo.net/forum/converge...ml#post1604028
Using the nanoFlash, one can achieve 1080p24 out of a standard NEX-VG10.
The 1080p24 includes synced audio.
Please post comments on our thread in the nanoFlash forum.
This post is to only inform you that the other thread exists.
Dan Keaton
Augusta Georgia
Old January 4th, 2011, 01:34 PM   #2
Very interesting Dan and many thanks for posting. Just responding to keep this from slipping down the list.
Henry Williams is offline   Reply With Quote
Old January 4th, 2011, 01:46 PM   #3
Dear Henry
This is very nice as the nanoFlash greatly expands upon the NEX-VG10's capabilities.
Many have wanted to be able to record in 24p.
And High-Bit-Rate Codecs are certainly nice to have.
Dan Keaton
Augusta Georgia
Old January 4th, 2011, 04:01 PM   #4
How is a 60i camera recording 24p in a NanoFlash?
Old January 4th, 2011, 04:06 PM   #5
the camera records 30 or 25p depending on region, then puts it in a 50 or 60i wrapper.
Old January 4th, 2011, 04:30 PM   #6
Dear Friends,
While Sony lists the camera as being 1080i59.94, it is actually putting out 1080psf29.97.
The nanoFlash is capable of converting the 29.97 Progressive Segmented Frames to
29.97 true progressive frames per second.
And the nanoFlash is capable of Over and Under-Cranking, thus allowing one to obtain 1080p23.976.
Dan Keaton
Augusta Georgia
Old January 4th, 2011, 06:32 PM   #7
Thanks very much Dan; this setup plus an HDMI splitter and field monitor settling one of the most oft quoted criticisms of the VG10 on the forum even without the framerate fix.. I think the cam is taking a little too much flak for not offering more pro features, which seems strange considering it's price point and consumer cam designation. It's great that we can use it for pro applications but we need to appreciate that it's a few thousand less than an af100 and cut it a bit of slack.
Old January 4th, 2011, 07:13 PM   #8
Dear Friends,
When one adds a nanoFlash, you get simultaneous HD-SDI and HDMI outputs.
Thus for the NEX-VG10, you can feed the nanoFlash with HDMI in, then get HD-SDI and HDMI outputs. You can use one, both, or neither.
Dan Keaton
Augusta Georgia
Old January 4th, 2011, 07:22 PM   #9
So the 24p is not usable with audio? Or the audio has to be recorded elsewhere? What scenario can we use this capability? It seems like a slight slow-motion effect would be obtained.
Old January 4th, 2011, 07:36 PM   #10
Dear William,
Yes, the audio will be in perfect sync in you are using the nanoFlash and 24p or 25p.
Just set the Crank On, with 24/24 or 25/25.
Dan Keaton
Augusta Georgia
Old January 4th, 2011, 09:19 PM   #11
Curious, makes the camera seem viable again to me. So "crank" effectively changes the frame rate of the camera to a true 24p if I understand correctly.
Old January 5th, 2011, 03:18 AM   #12
Dear William,
The camera actually put out 29.97 Progressive Segmented Frames per second.
Then the nanoFlash discards just enough frames, in an appropriate manner, to obtain 23.976 frames per second.
This is a process where we take x number of frames then skip one, then repeat,
Dan Keaton
Augusta Georgia
Old January 5th, 2011, 07:18 AM   #13
This is not very sophisticated. 30p down to 24p means 1 frame is removed every five frames. Without frame blending, this causes motion to appear choppy. And 30p (which the NX10 is producing) is notoriously difficult to frame blend into 24p. There is nothing in the nanoFlash spec sheets that indicates frame blending is part of the hardware. The example here is of a still life, we need to see real motion.
Old January 5th, 2011, 07:32 AM   #14
Dear William,
No, we do not do frame blending.
Gerado posted a video with motion. I will go find it.
Dan Keaton
Augusta Georgia
Old January 5th, 2011, 07:36 AM   #15
HDV Cinema
William has it right. The time between frames for 29.97 simply can NOT be be made to be the time between frames for 23.976.
The math doesn't work. This is Sony Cineblah all over again. The software chooses the nearest in time frame to record. It will look just like 24fps with the Z1. (Please don't let me ever see this Sony demo again!)
Only if motion compensation -- a huge computational task (think hours per minute) -- is done by Twixter can this be done. And, there is in no way certain the new series of frames will look PERFECT.
If you want 24p, I don't know why folks ignore the real solution: Twixter. It never gets mentioned, yet for several years it keeps doing the job.
Now could 25 be converted to 24 -- I doubt by the nano.
Steve Mullen is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony NEX-VG10 / VG20 / VG30 / VG900
