#121 |
All you need to know is that you can get true progressive frames from it. Although not silly 24p.
As Alister pointed out on the first page this *isn't* the prototype that was shown at NAB. So expect the EX beater to be announced later. Personally I've had enough of the darling camera phase and I won't be chasing tech any more. I you want me to use a particular camera then hire it and I'll come along and use it for you. Otherwise put up with what I own already. |
#122 | ||
The other side of the coin is that 1080i/25 and 1080p/25 have the same amount of uncompressed data per second - the approved nomenclature makes that more obvious. I am now finding it easier to always talk in frame rates. Quote:
#123 |
Thanks. Actually all I meant was how do you type the terminology - i.e. 1080psf/30 it seems.
#124 | |
Ron Evans |
#125 |
There may be 30 frames per sec in both cases, but how those frames are constructed is different.
#126 |
I think that the problem comes with how motion ends up being represented - I may be crazy, but I swear I can see almost a stop motion effect with 30p stuff I've shot - it appears I'm not alone in this, so I feel a bit more vindicated. 60i looks "smoother" and more natural to my eye.
Strangely, when I render out to 24p from 60i, it still looks smooth, when it "should" look worse, I may have to experiment with some of the 30p stuff I've shot and see how it renders out... Now this is really beginning to gnaw at me... |
#127 |
With a sensor that huge if it doesn't at least outperform the EX camera in low light I have no use for them. Even If this camera doesn't at least it encourages other companies to release something that will.
EX3, Q6600 Quad core PC - Vista 64, Vegas 8.1 64bit, SR11 b-cam |
#128 | |
Amen brother. Too many options! I'm falling back into digging for stories and content. Like Yogi Berra said to a future Hall of Fame 2nd baseman: "Keep it simple stupid." I'm tired of chasing tech too. I mean it seems to me the purpose of these cameras are to sell lenses!
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center https://www.youtube.com/user/JacobsESCG |
#129 | |
This camera completely identifies the weakness in the standard. 30P in 60i and 60i are called the same but they are very different. Ron Evans |
#130 | |
To try and move on, if we can all agree it's 1080psf/30, I'd like to return to the question I put in post 76 - why ONLY 30psf, why not 1080i/30 AS WELL? It's a consumer camera, and traditionally 1080i/25(30) has been Sonys primary mode in these? As I said before, "It's only a theory, but MAYBE, just maybe, it could be because they can read out the entire chip prior to downconversion at 25Hz, but not at 50Hz? Doing that, rather than the arrangement used in most current DSLRs would be a huge step forward since it should take away many of the aliasing problems and give far better sensitiivity. Just a thought." |
#131 | |
#132 |
David, I may have missed something in the discussion along the way but I have been using my Z7 (1/3" chips) with a f1.4 "pro" Fujinon lens which is a faster lens than the stock lens and should give a shallower depth of field. And I have a DSLR which has the same size image sensor as the NEX-VG10 (APS). My DSLR camera came with an 18 - 200 f3.5 - 5.6 lens which is very similar in spec to the stock VG10 lens. And I am sure that that I can achieve a great deal more bokeh with the DSLR and the standard lens than the Z7 can ever hope to achieve with the even better f1.4 lens. The APS sensor is HUGE compared to a 1/3" chip. I thought I saw something that said it is 15x larger. That is a lot of difference And from what I understand, 35mm movie film is approximately the same size as an APS sensor and so is the RED ONE camera.
#133 |
For those that have pre ordered this camera. What Memory cards are you using or recommend?
#134 |
I already have sandisks 16GB class 6 cards from my T2i that I will be using and also a couple of Transcend Class 6 16GB cards as well. Hope this helps.
#135 |
Greg, I would say the 1/3" chip camera at f1.4 would be roughly equivalent to the new Sony camera at f8 for equal DOF.
