[Camera Profile] where are saved on SD card? at DVinfo.net
Sony NEX-EA50 (all variants)
Old December 9th, 2013, 05:29 AM   #1
the nex ea50 can save pictures profiles PP1-6 and save on camera... but from menu' (Others) you can save/load up 99 settings of camera.
this is very usefull, because you can make "ready§ your cam in any situation/set you like...example you can made another 6 different picture prof. and load if you need ecc..ecc..there are many combinations.
but...the setting are save on the same SD is used for recording...
SO bad is...if you format the sd you lose all your save settings, and also if you change SD...you not have more your setting ready to load on your cam.
One solution is saver your settinf on one separate SD to use only for load the settings ,
the another solutions is BACKUP the settings ins every SD you like take for your works...
PROBLEM/QUESTION:
where save the setting the cam on SD dir/names ? can we copy them and put to another formated SD, directly with a computer ?
the best can be a little software, can read and copy and save them form a computer, and meaby also a interface for change by software every set inside...
Jimiz Zanei is offline   Reply With Quote
Old January 12th, 2014, 12:36 PM   #2
Re: [Camera Profile] where are saved on SD card?
On sd card: private/sony/setting/ea50p/CAMPRO01.DAT ...02.dat...03.dat
how many are the setting saved
you can save on HDD , backup on another sd card...and never lose.
