Sony Anounces 3 new E-Mount Lenses
Here is the B&H Photo (a DVINFO sponsor) page that details all three.
Sony NEX Lenses | B&H Photo Video Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
Re: Sony Anounces 3 new E-Mount Lenses
I'm quite excited about the 18-105 f4 power zoom. It would be perfect for shooting live shows in smaller venues. The kit lens is too slow for that but with f4 I would have a tad bit more light at least when I don't need the full range of the 18-200...
They were also much cheaper than I thought they'd be, expected them to be close to €1000, but at €599 they are almost affordable ;) And I wish there was a trade-in program to exchange the silver 50mm for the new black ones... The silver lenses just look silly on the EA50... I still dream of a 35-150 2.8 power zoom though... ;) |
I find a massive difference between F4 and smaller and my constant F2.8 lenses. They are a joy to use. So a constant F4 isn't really going to give you a huge amount of advantage when wide (actually slower than the stock lens at 18mm) but I can see the gain higher up if you tend to use high zooms.
I would be perfectly happy with a 16 -70 zoom at F2.8 in an eMount ... For wide stuff I still love my Tokina 11-16 F2.8 and at present I'm using a Tamron 17-50 F2.8 for higher zooms but that's where it ends (of course both are manual zooms and manual focus but the EA-50 does a good job with auto exposure!) Chris |
But if you want constat aperture on the stock lens you have to set it to f6.3 if you don't want it to change when zooming. f4 then is quite a bit of a difference. Maybe then I can use 15dB of gain instead of 21dB ;)
I'd say I'm usually in the 40mm-100mm range, and the stock lens is already at f4.5 at about 30-35mm. And as I'm filming live events with one camera, sometimes two, the power zoom is invaluable. It won't be the huge difference I would like, but hopefully a nice step. |
#5 |
Dmitry,
The fast 50MM f1.8 with the digital zoom would put you close to your working range at 75-150? For your stage shows bringing down the ISO would compensate for the small amount of loss with the digital zoom. Just a thought. Steve
#6 |
The new lenses look great but I have the 35mm 1.8 and kit lens and find it harder to manual focus with them.... turn the focus ring a 1/4 turn clockwise then a 1/4 counter and you are not back where you started .
The 18-105 is really looking good to me, and the fact that I could use it in a matte or just zoom without the balance changing is really nice "Internal zoom and focus design helps to maintain a constant lens length with a non-rotating front element to support use of polarizing filters." |
#7 |
Ray,
Yes it zooms and focuses internally, but it is still a "servo" lens. If you are expecting it to feel and focus like a traditional all manual lens you might be disappointed. I could be wrong but I have never yet found a servo lens that focuses well manually. Fortunately, the EA50 has an amazing focus peaking function. The best I have ever used. I run mine on yellow, fine or medium. It is spot on. Steve
#8 | |
#9 |
I've been using the 50mm on occasions. The digital zoom is only 2x so it gives me 50-100. And the digital zoom seems to be adding artifacts I'd rather avoid, if possible... Also, I'm still hoping to soon(ish) upgrade to a FS100 or FS700, then no digital zoom will be available... But with my current financial situation, that will be a while ;)
