December 5th, 2013, 04:02 PM | #16 | |
Re: Stage shoot Settings?
Ron Evans |
December 5th, 2013, 04:54 PM | #17 |
Tom,
It is AE Shift. You set the value you want in the menu. You can also turn it on and off there. If you assign a preset button to it, that button will activate it to the level you set. Thanks for the info Ron. And yes, rapidly changing theater lights has always been a difficult situation to shoot in. Especially when the LD designed his look for the human eye and not video exposure latitude. That is why I love to be there for dress rehearsals if there is one. Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
December 7th, 2013, 11:43 AM | #18 |
my 2 bits concentrate on focus and exposure leaving wb til post
December 7th, 2013, 12:53 PM | #19 |
Yes I have all my cameras set for indoor WB. With a mix of tungsten and LED ( that can have variable white balance ) lights these days that can change from scene to scene it is almost impossible to get one setting correct for the whole show. Better to do it afterwards. Focus is critical especially in HD and under expose a little. Fixed camera set for AE shift of -.5 to -1.0 and occasionally the medium shot camera with Spotlight or full manual depending on what is happening !!! Easy to make lighter not so easy to replace lost highlights.
Ron Evans |
December 8th, 2013, 03:39 AM | #20 | |
When I set it off It goes to 0? For stage I will set it to -1 or -2 I think. |
December 8th, 2013, 11:16 AM | #21 |
Can't speak for the AE50 but for my small Sony cameras I set them to -.7 if the set is light and -1 if there is darker scenes or more contrast. Simplistically if you think there is a lot of darkness in the shot go more negative to stop the camera opening up too much.
Ron Evans |
December 11th, 2013, 10:50 AM | #22 |
Tom,
Let me be more specific. You said you set the AE shift and you assigned a button to it. The button will then give you three options: 1. ON 2. Off 3. Set the value Anytime you see the white box around a number on your viewfinder the camera is telling you it wants you to pick a value manually. Some times you select the value with the menu wheel and sometimes it is the iris wheel. Steve
