#46 |
Re: EA50 - B camera ideas
Still working on that Noa but will post once I have satisfactory results. I have dabbled with your JR45 Cine profile but am finding it too contrasty and a little red, so continuing some tests.
#47 |
Hi James
Peter and I shot last weekend's weddings on the PP3 profile with colour level lifted from zero to +4 and I must say I really like the result!! Pete will also be posting his results later too! It's worth a shot? Chris |
#48 |
Of course Craig, thanks I will give that a try.
#49 |
They are not my preset, I just copied it as well from another source :) But you are right that the reds are more pronounced but I don't find it contrasty, it's actually quite flat.
#50 |
Hi James,
The match for the loaned VG20 I was using with my EA50 was just PP1 or off (i see little difference between those two anyway). I was shooting corporate meeting lectures so the match was great. I do not have to get real fussy with those shoots. I was using my Canon lenses and everything looked good. For you guys that are tweaking every last pixel of perfection out of it you might not be as happy as I was. I am now shopping for a VG 20 or 30 on E-bay. I have never purchased a used camera of any type before. Or a new one from E-bay. I get most of my stuff from B&H. In this case, for a cheap "B" cam and fly cam the E-Bay prices are about half and it is not a big investment so I will probably pick one up pretty soon. I will let you know if I still think it is that great after I put more time in on it. I still believe it is a good "B" cam for the EA50. But you are correct that is not true once you start utilizing the versatility that the EA50 comes with. Are you happy with your VG30? Does the cine profile match PP5 on the EA50 by any chance? I did not get a chance to compare them. Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
#51 |
To be honest I have been struggling with the new cameras. The ea50 can achieve some amazing stuff particularly with the focus transition tool, perhaps worth buying the camera for alone, I wish the vg30 had that function. The ea50 is fine when you have all day to set up a shot but for weddings it is quite cumbersome in too many ways to list them all and the LCD is far inferior to that on the vg30, next to useless if you ask me and with no viewfinder, you need to have done a lot of testing before. But I have the camera now so will stick with it. Am probably going to get a canon xa20 to use alongside the other two, I miss my fast long zoom and desperately want it back!
#52 |
Realy? Why do you find the lcd of the ea50 useless? Combined with the focus aids you get like peaking, magnification and spotfocus during record I find it the best lcd I have used so far on any camera I had in the past. I can understand the lcd of the vg30 to be superior from what I have read about it but useless?
Also watch out with combining footage from a xa20, the sharpness difference between the 2 camera will make matching images difficult, I allready have this with my cx730 and those are not as pin sharp as some camera's out there. |
#53 |
The Vg30 has a high resolution O-LED viewfinder and this is a big upgrade from the Vg20. (an O'LED viewfinder is a $350+ option for an NEX-5!) Both VG20/30 cameras have silly little swing-out LCDs and IMO, the only thing they are good for is setting up the menu prior to a shoot. I would not use the LCD as any form of reference during a shoot.
#54 |
James,
The EA50 is designed to be an event camera. Weddings, corporate events, and run and gun are its strength. It is not a cinema cam. Focus Transition is on the bottom of my list of features this camera offers. Maybe your trying to over think it? I would like to hear more about what your doing with it. Maybe we can help? Steve
#55 |
Hi James
Am I right in saying that you are the one who doesn't use the viewing tube either?? I trust the focus peaking on the camera in manual and that's all I use ..I certainly wouldn't try to focus without peaking!! As for focus transition if you are shooting manual focus anyway wouldn't it be a lot easier just to do a manual shift ..that's how it was done in the old days!! I use my viewing tube PLUS a 52mm CU lens (+2 dioptre) screwed into the top and it makes a huge difference to me ...maybe that's worth a try. After using 260K LCD's on my Panasonics the EA-50 to me is amazing resolution but I still wouldn't use just the image on an LCD for focussing anyway Chris |
#56 |
All I know is that focusing without peaking was much easier with my z1, obviously smaller chip so bound to be but it is the LCD in bright sunshine that I find to be the problem and I don't like the viewing tube. I would never have used focus transition in the past but I do find it to be useful on this camera with its larger sensor. Must be me but I still have my reservations about this camera for weddings.
#57 |
Well, so far I have been really delighted with the cameras (I have two of them) at weddings but then again I had Panny HMC82's previously so the Sony's should be better. Even shooting weddings with the stock lenses have been great..with run 'n gun handheld the big sensor takes a little time on AF but nothing that causes any issues. My season is over now but I did the last 16 weddings of the season all on the EA-50's and brides are happy. The only extra's I have are a Tammy 17-50 F2.8 constant for low light Churches and also a Tokina 11-16 F2.8 for stuff when I just want to point and shoot like guest interviews
I've used both the stock 18-200 and the 17-50 at weddings as even with the 18-200 I run in manual ...The 18-200 using AF on the stedicam also does a great job. Different strokes for different folks but I found the transition from 1/4" chips to big sensor painless ..yep I certainly wouldn't attempt to use the LCD without the tube even if you use the shroud part of the tube in bright sunlight. Focus Peaking is always on with both cameras! Chris |
#58 | |
#59 |
James please let me ask a question. Are you relatively new to shooting weddings? The reason I ask is because the EA50 is a wedding camera and some very picky veterans here are quite happy with it in that environment. I am trying to figure out how I can offer assistance, as you say you are struggling with it. I have been in this business 20 years, commercial, not weddings. My point is, that kind of longevity meant we had to learn how to shoot first and foremost. The cameras did not do anything for us. I am wondering if it is technology you are disappointed in, not the specific camera. Some guys get so caught up in the technology their expectations from the camera become unrealistic.
I bring this up with all due respect. I know nothing about you. The EA50 is a general utility type camera designed with weddings and events in mind. It does a very good job of that. I am trying to figure out why you are struggling with it so I may offer assistance.
#60 | |
Those are all things that make the camera difficult to handle in run and gun when you use the stocklens, you could let it all in auto if you are afraid you might mess it up yourself when it goes too fast but the risk of letting your camera mess up is bigger as well. |
