Genus Eclipse ND Fader filter test - Page 3 at DVinfo.net
Sony NEX-EA50 (all variants)
Old April 4th, 2013, 12:37 AM   #31
Re: Genus Eclipse ND Fader filter test
Yeah I got mine really quick as well. I don't like that it doesn't stop on the min/max ends of filtering. On the Heliopan for example when you rotate it, it will stop when it hits the min and max amounts. The Genus Eclipse filter doesn't have any stops so it just keeps rotating, meaning I have to look up from the oled viewfinder, set it to min visually, then back to the viewfinder to make my adjustments. Not a huge thing but I like how on the Heliopan I can set it blind without ever leaving the viewfinder. The hood on the Genus Eclipse though is very cool, I think it vignettes slightly on my full frame video camera at 50mm, but at 70mm It seems ok (at full hood extension), although I haven't really tested that in detail. What's neat about it is that I can use the hood and still tweak the nd setting on the filter. With the Heliopan you can put the lens hood on there, but then you can't really adjust the nd filter setting after that because it gets blocked. Anyways I have a shoot tomorrow so I may give it a whirl.
Peter Siamidis is offline   Reply
