EA50...problems problems
Hi Guys.
I wanted to start by saying great site and it's certainly reassuring to have so many others finding their feet with the exact same camera model. I've had the EA50 here in the UK for about 2 weeks and have so far been really disappointed with the camera. Actually let me rephrase that, I'm disappointed with the output I'm getting with the camera. A good percentage of this I'm sure is down to my lack of familiarity The EA50 purchase was to assist me in developing my modest video business and try give me greater flexibility over my current EOS DSLRs. I got to the point with my Canons whereby I felt that I was paying more and more money to work around the ergonomic issues of the DSLR body. The EA50 certainly is a good fit due to it's fairly good ergonomics and I liked the build quality. However I've really struggled to get usable footage from it. The zoom lens capability is clunky and I have like others mentioned suffered from the jerk in the zoom, which Sony tells me is down to the torque of the zoom mechanism on the optics...mmmmm I've also had other minor issues around moire, low light performance and also pixalation of footage when imported via Final Cut Pro X. I'm giving serious thought to returning the camera, for me the original deciding factor was not one based on budget but more ergonomics. What are other peoples thoughts??? Also I wanted to shout out to Jerome for his kind message back to me following an email I'd sent him! Matt |
Re: EA50...problems problems
Having spent an hour or so looking at other people's footage on here, I just can't possibly see where I am going wrong.
My footage in comparison is very pixelated, soft and full of moire. Can I ask how people have they're EA50's setup? I'm starting to think I may have a setting incorrect somehwere which would explain the difference in my cameras output. One thing I have noticed is that within Final Cut Pro X, when i pause a clip it instantly sharpens up, then when i play it agin it goes very soft. I'm starting to lean more on me possible being an idiot than the camera....so a simple setup masterclass would be massively appreciated???? |
#3 | |
If so (and I suspect the answer is it will), there is nothing wrong with your camera, and no issue with it - what you are seeing is an FCPX problem....... |
Have you set it to a lower resolution somehow? Is FCPX using Proxy media?
#5 |
Hi guys, as far as I can tell I'm filming at 1080p 60p.
I'll check the footage directly from the camera using a hdmi cable. See if it's indeed an issue with FCPX....really frustrated. Having moved from my DSLR I knew there'd be a learning curve but I'm finding using the camcorder a real chore. Out of interest what's the best setting, using my EOS I'd capture at 24/25fps. I was confused by the PS and FX settings. |
#6 |
Sadly the footage looks no better on my tv....mmm
Can someone possibly give me a setting up run through? I could then try a test shoot and upload my test? Any help would be massively appreciated! Matt |
#7 |
Matt
Can I ask who's footage you've been watching. The majority of video's I have seen have been done with prime lenses, not stock. Which makes a significant difference if you ask me. Especially Noa's short films. I completely understand the moire problems your having. I done a wedding event the other day and 3 guys had stripey shirts on which had severe moire. I don't think they will pick up on it when I give them the final film but it stands out in my eyes. I still wouldn't return the camera though. It is the only affordable (if you can call nearly £3000 affordable!) ENG style Cinematography Camcorder available in the market. And as you said the Ergonomics is very important. I can imagine Sony coming out with an upgraded version next year rectifying these issues. An EA60 perhaps? |
#8 |
Hi Matt
The stock lens is also great of course, and Noa has done some cinematic stuff on the stock lens and was pleased with the results. I bought primes and resold them as I though the 18-200 was just as good and more convenient. OK ...Just for now, shoot a bit of footage at either 1080 50i or 25P and take a look at it ...plenty systems struggle with raw double frame rate on playback. Set your Picture Profile to PP3 ...other settings "off, PP1 and PP2" are quite saturated so they may appear soft and "PP4, 5 and 6" are also quite contrasty and cinematic so doing a check on PP3 is a good idea ... indoor footage will look great but outdoor in bright sun normally needs a saturation lift. Like 99% of pro cameras, the settings are not really good "out of the box" I would also suggest read the manual and read the forum posts before selling it..you will regret it!! Chris |
#9 |
Can you place something you have shot on Vimeo and give the possibility to download the original file you have uploaded for us to check?
I would also expect that the stocklens is not better then my primes but I was very pleased with the image quality of my sahara video (which was shot with only the stocklens) |
#10 |
My only problem with the stock lens is that it's too slow as I mostly work in rather dimly lit situations, so that shouldn't be the issue.
I also use FCPX which works just brilliantly. Can't really think of a setting (other than recording in SD) that would wreak such havoc to the image. |
#11 |
Hi Guys, yesterday I went out and did a test shoot on location for a bleak drama I'm involved with.
It's a rather depressing location and I was told to not introduce any additional lighting if possible. So I went yesterday with the EA50 and did some simplistic shots of both the house and the road on which it's built. Ignoring the motion of the shots which is down to me...I'm still struggling to get a better quality picture. This was all done using the servo powered kit lens. As previously mentioned any help would be massively appreciated. test 1 - YouTube Here's a vimeo version also: Last edited by Matt Edwards; March 18th, 2013 at 03:23 AM. |
#12 |
It would help if you told us what you don't like about the shots in this video?
#13 |
I just looked at the vimeo mov file that I downloaded and there are some issues I see:
Around 00:20 you are zooming out in that hallway, did you apply a stabilizer in FCPX to that shot? The image deformed in a way that is typical for software stabilizers. You do zoom a lot, you have to know that if you would focus manually that this lens does not keep focus through the entire zoom range, so that might result in softer images if you don't check and adjust your focus accordingly. From what I saw in the video the focus was on auto as you could see the focus adjusting while you where zooming out, that can result in some rapid focus shifts as the camera is trying to adjust. This was best visible at 01:02 at that coffeepot and at 02:02 when you zoomed out you had a very bright kitchen window in the back which made the camera struggle to keep focus. The shot at the stairs at 01:16 is a simple one, you zoomed in making the lens ramp to maybe around f6, that has to be compensated with gain and the combination of a slow lens and high gain results in excessive noise, here are 2 options, you use a light or a faster lens. I did see some moire but there you can be sure it is a lot less then on canon t4i, 7d or 5d2 type of dslr's. I have not tested it yet but it has been said that turning down the sharpness in camera and add sharpness in post would reduce moire. If you ever run into a severe kind of moire you can change your frame by zooming in a bit which will decrease the moire or don't pan at all, panning makes it worse. All other images looked ok to me. About that clunky lens, Alister Chapman also noticed it on his pre production model and it seems it is just a design issue that can't be fixed, but on the other hand, where can you find a motorized servo zoom lens with autofocus and smooth iris adjustment through the camera for large sensor camera at that price point? For it's price it's a great "all purpose" lens, even with it's disadvantages. I have been shooting outdoor by adjusting my shutter to cope with the incoming light but I plan to get a variable nd filter this week to keep the shutter at 1.50th for a more natural "moving blur" on moving objects, it also could be if you are using very high shutter during a pan or a zoom that this could have side effects to your image as well. What functions do you let the camera handle automatically and which do you adjust manual? |
#14 |
Hi Noa
Thanks for your comments really appreciated. As I said this was a very quick and dirty test. Having come from using a Canon DSLR I'd imagine the servo zoom to be perhaps more useful than it is, hence why there's a fair bit in the footage as it's a new novelty for me. You were right about the software stabilisation and the auto focus. Where I'm struggling I think is the gain functionality on the camera and also the PP modes. Put simply I don't know which manual settings will work for the best. Having read the manual cover to cover I feel I'm no further forward....Perhaps I'm stuck in the mechanics of the DSLR....I knew the move would be challenging. By the way I think your Sahara video is very nice, it's got a lovely colour palette and there are some excellent cinematic shots in there! |
#15 |
You have been using a dslr? Which one?
The ea50 works in the same way as a dslr really, I actually find it easier to work with then my canon 550d, since you have been working with a dslr (that has to be used in full manual mode to get the best of it), what do you see as a challenge when working with the ea50 compared to your dslr? |
