SD to CF Memory Card Adapter at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old July 29th, 2012, 06:03 AM   #1
A friend was telling me about the possibility of using an SD to CF adapter in the MRU. Has anybody tried this and how well did it work? Thanks.
Lee
www.leebergermedia.com
Lee Berger is offline   Reply With Quote
Old August 2nd, 2012, 02:52 PM   #2
Re: SD to CF Memory Card Adapter
I have a cheap SD to CF card adapter & it didn't fit into the MRC1 recorder. (I think this is a CF type I & type II, where one is thicker than the other.)
The biggest concern is the speed of the adapter & the SD card. If either of them is too slow, you could have massive errors in writing video.
Bottom line, if it is cheap enough for you to try it out & no work, then try it out before you use it on a real job.
Zach Love is offline   Reply With Quote
Old August 2nd, 2012, 03:37 PM   #3
Thanks Zach:
Actually a friend of mine in town has ordered one. Once he's tested it I'll report back here.
Lee
Old November 5th, 2012, 09:16 AM   #4
ANy news??
Lee Mullen is offline   Reply With Quote
Old November 5th, 2012, 07:23 PM   #5
Yes. My friend did successfully use the SD to CF adapter. He said it was a tight fit and that was enough for me to decide it's not worth it for me.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
