converting IDX or M2T files to AVI?? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old June 30th, 2011, 01:49 PM   #1
Is there a way to convert IDX and/or M2T files to AVI? I have captured clips from tape to CF card via the MRC1 recording unit...but my Adobe Premiere doesnt recognize these video files...so I canot capture in the editing software? Can someone help me?
Also, Premiere does not recognize the Z7 even in tape capturing mode...am I doing something wrong?
BTW...Im using a MacBook 17.
Thanks ahead,
Jake
Jake Latendresse is offline   Reply With Quote
Old July 27th, 2011, 01:47 PM   #2
Re: converting IDX or M2T files to AVI??
What version of Premiere are you using?
I've pulled in some clips from my Z7 through Premiere w/o much trouble. Should be the same process you pull footage from P2 or XDCam EX.
Zach Love is offline   Reply With Quote
Old August 1st, 2011, 12:28 PM   #3
Jake, I've had the same issue with Premiere not recognizing the camera, so when I capture from tape, I capture through Final Cut and then bring my MOV files into Premiere.
As for your M2T question, there's some relatively inexpensive software out there called "Clip Wrap" which will wrap your M2T files with a QuickTime extension so that they'll play nicely with older versions of Premiere (CS4 and CS5 both accept the M2T files without any trouble though), but then you'd have to use another program (maybe Mpeg Streamclip?) to convert the MOV to AVI.
Hope this helps!
Adam Flaherty
AF MEDIA, LLC | HD Video Production | Maine NH MA Boston Videographer
AF MEDIA, LLC :: Video Production & Website Design - Shopping & Retail, Business Services - Portsmouth, NH | Facebook
Adam Flaherty is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
