shutter question at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 4th, 2010, 11:00 PM   #1
shutter question
My Z7u when I put my shutter speed to 60, I see a slight banding brown color slowly moving up my screen, but when I crank my shutter to let say more than 170 or if I set it to auto mode the banding disappears. This only appears when Im shooting under florescent situation. Do I need to twick something in the settings to get rid of it? Thanks.
Rickey Brillantes is offline   Reply With Quote
Old March 5th, 2010, 01:22 AM   #2
By default, FLCKR REDUCE (p. 70) should be on, but it doesn't always work. You've discovered the solution -- use a slower shutter speed. Or leave it in auto.
Old March 6th, 2010, 05:26 AM   #3
I've noticed this as well and I think it's possibly a bug in the camera that causes it not to sync with certain fluorescent fixtures even when the shutter speed is locked on 1/60. For me the fix has been to switch to auto shutter and back to fixed. The sync problem does not happen every time under fluorescent and therefore requires careful attention to the possibility it may occur.
www.leebergermedia.com
Lee Berger is offline   Reply With Quote
Old March 6th, 2010, 12:31 PM   #4
According to the manual pg 107, This occurs when recording pictures under a fluorescent lamp, sodium lamp, or mercury lamp. This is not a malfunction. This can be improved by changing the shutter speed (p. 31).
But the thing is that I notice it after an hour of shooting and what really sucks is that i cannot use the footage. oh my, oh my! Luckily it's not a paying gig. It's just my son doing his science project presentation at school.
Old March 9th, 2010, 05:44 PM   #5
You are encountering CMOS line by line readout.
50hz FLUO vs 50Hz (~) that dont match 100%
in 1/60 (or higher) the fluorescent does not fill your screen 100% each time and because 50hz dont match the "shadow" part of the image slowly crawls...
uli
Uli Mors is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
