Audio too hot at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old November 1st, 2009, 02:02 AM   #1
Audio too hot
When i import to final cut pro the z7 camera audio is always 6 to 12db too hot .Should i adjust camera recording levels down 12db? My audio is never distorted just too hot.
Brad Bell is offline   Reply With Quote
Old November 1st, 2009, 09:32 AM   #2
Does the Z7 come with a trim adjustment? On the Z5 I trim the audio to -6db. I shoot in loud venues and that helps.
Rob Morse is offline   Reply With Quote
Old November 1st, 2009, 12:04 PM   #3
if you're using the oncamera mic to capture audio and it's coming to you hot why wouldn't you adjust at the camera to lower the levels so it doesn't clip? Seems pretty logical to me. If you're pulling a feed from a mixer then the adjustment needs to come at the mixer. The better the sound coming in to the camera the better the sound will be in the finished product.
Don
Don Bloom is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
