Compact Flash 'Format Error' at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old October 2nd, 2009, 11:00 AM   #1
I was shooting with my Z7 today, recording (thankfully) on tape and compact flash. I noticed the LCD display flashing 'CF' whilst recording and I noticed an error message on the compact flash unit saying 'Format Error'.
I've put the card into the PC and it's saying something like 'drive K is not formatted, format now?'. I've clicked no, but I wondered if the files are easily recoverable from the card, otherwise I'll just capture the tape.
BTW, I was recording in DV and on a 32GB Kingston card (133x write speed).
Matt
Matt Bigwood is offline   Reply With Quote
Old October 2nd, 2009, 11:31 AM   #2
I suspect that you had deleted the previous files from the card, via your PC? Sometimes when I do that, the card will read 'format error' and needs to be reformated before it will record correctly.
Richard Alvarez is offline   Reply With Quote
Old October 2nd, 2009, 02:05 PM   #3
No, I had formatted the card before the recording. I had recorded a number of files on the card until the error occurred.
Old October 3rd, 2009, 01:27 AM   #4
Had you formatted the card in the Z7 card slot or on your PC?
Stuart McAlister is offline   Reply With Quote
Old October 4th, 2009, 04:36 AM   #5
I had formatted it in the Z7.
Old October 4th, 2009, 04:44 AM   #6
Mmm ...
Well your card sounds like a UDMA (133 speed) and you formatted in the Z7.
Do you use the card for anything else? When you look at the card on your PC, are there any 'locked' or 'protected' files on it?
The camera link is 'on' (when mounted on the Z7)?
Does the Kingston card come with a 'retrieval' software package?
Stu
Old October 4th, 2009, 12:34 PM   #7
I've got a felling it's a bad card. I've only used it two or three times before I had the problem. It didn't come with any recovery software, and when I tried a (free) generic recovery program it said the media was too badly damaged to recover the files.
The card has only ever been used in the Z7 and formatted in the Z7 too.
Old October 5th, 2009, 02:01 AM   #8
Matt,
Fair enough. Depending on how long you have had the disk, you could always return it for a refund or an exchange.
Just as an idea of a replacement, I have a pair of 16Gb UDMA Lexar cards (with a Lexar reader). It comes complete with a software retrieval package and most popular internet resellers stock these items.
Let us know how you get on.
Stu
Old October 5th, 2009, 02:37 AM   #9
Hi Stu
Yes, I'm going to contact the retailer to get an exchange. I've got four compact flash cards, a Sandisk Extreme III 16GB, a Kingston 133x 16GB and a Hama 32GB 200x, besides the errant card. They've all worked fine so far and I've shot many hours of video on all of them.
I'll let you know what happens.
Old October 20th, 2009, 01:39 AM   #10
Kingston 32GB 133x
Hi
I had the same problem But i think it is no problem with the Kingston card just a problem of compatibility. I have used my Kingston card for more then 8 months in my Canon 5D mk II and i had no problems what so ever, and last week i wanted to use with my Z7 and had "Format error". So i think the card is OK but sometime can have a conflict whit the Z7. I will newer use Kingston 32GB 133x in my Z7, but i will use in Canon 5D mk II.
Zoltan Lorincz is offline   Reply With Quote
Old November 13th, 2009, 12:58 AM   #11
I've just been reading this post and thought I offer some of my experiences with CF cards and the Z7. I initially had problems with cf cards that had slow speeds below 300x. I'm know using a 64 gb card that is 500x speed and haven't had a problem. Prior to this card I was using a 16gb card 300x speed which also worked fine.
Jon Wilson is offline   Reply With Quote
Old November 14th, 2009, 06:23 AM   #12
I agree with Jon, speed seems to be a factor. The threshold for success seems to be around 266x. Anything below that has not been reliable for me.
Harry Christensen is offline   Reply With Quote
Old November 15th, 2009, 06:20 AM   #13
What make is the 64gb card Jon? Do you have a supplier please?
Hedley Wright is offline   Reply With Quote
Old November 15th, 2009, 08:38 AM   #14
SanDisk Extreme Pro in 16, 32, & 64 GB.
Old November 16th, 2009, 10:21 AM   #15
Whooooo - not cheap are they ;)
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
