TC difference between HDV + SD conversion at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old April 16th, 2009, 08:51 AM   #1
I played around with the realtime SD conversion via Firewire ("iLink HDV->DV") and just found that if you do a conversion to SD your timecode will be shifted + 1s04f on the same frame compared to the original HDV timecode.
See
www.morsmedia.de/downloads/z7_morsmedia.png
(big sized pic is SD converted pic, PiP is the HDV original)
Just in case anybody uses that feature with a timecode list or EDL ...
Regards
ULI
Uli Mors is offline   Reply With Quote
Old May 4th, 2009, 02:37 PM   #2
solved by testing
First: The Z7 is not guilty at all.
I today found that my capture application HDVSplit produces faulty emedded TC in the m2t files. (see other thread).
After using Vegas Pro 8´s internal Capturing Tool (HDV , DV) I experienced that the timecode is absolutely ok - both in the HDV and the DV file.
Though I like the tool, I´ll abandon HDVSplit from now on from my harddrive...
Sorry for the confusion, hope this helps if anybody is in the same multicam business...
Uli
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
