White Balance at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old April 16th, 2009, 02:39 AM   #1
White Balance
Hi to al Z7 / 270 users!
I am wondering if there is a way to see the Kelvin Number AFTER doing a manual WB.
The number is shown for a moment after WB, but replaced by "<A>" (or B) and doesnt show up when checking Status.
Is there a way to check the stored value later too?
Didnt find a way yet except switching between A/B/P, what I need is a quick check of the actual setting/Kelvin value while or before shooting.
Any idea?
ULI
Uli Mors is offline   Reply With Quote
Old April 16th, 2009, 10:10 AM   #2
Hi Uli,
Wich model are you using?
Can't you check this with the MENU/STATUS switch on the HVR-S270?
How this is done on the HVR-Z7 I don't know.
Ivan Snoeckx is offline   Reply With Quote
Old April 17th, 2009, 12:30 AM   #3
No.
Status Checks shows everything from audio metering/settings up to recording formats or button assignments. There is a WB value showing up, but this is only the dialed in preset value - not memory A or B.
I played with it a lot but did not find a way to read out the kelvin values from A or B yet...
Anyone?
Uli
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
