Question For Z7U Nikkon Adaptor users at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 9th, 2009, 08:43 AM   #1
Hi there,
I recently acquired a Nikkon adaptor for my Z7U so I could attach a Nikkor 80-200mm long lens to it.
One thing that I noticed is that, once attached, if I grip the end of the long lens and try to rotate it while it is supposedly fixed it moves ever so slightly. In other words it rotates just a tiny little bit. It is a very small movement--maybe a millimeter or a fraction of a milimeter--but it bugs the hell out of me because I know that since I'm using a long lens the image will be sensitive to even slightest movement, so I want that lens to be solidly fixed in position, just like the Zeiss lens that comes with the camera is.
It appears that the Mike Tapa adaptor attaches solidly to the camera and does not move one bit. It is when I attach the lens to the adaptor that the lens moves that itty tinny tiny bit.
Is this normal? Have those of you who use a similar configuration with this adaptor experienced the same? Is this a limitation of this configuration or should I be returning the adaptor and exchanging it?
Hope the problem makes sense as described!
Raul Barcelona,
New York, NY
Raul Barcelona is offline   Reply With Quote
Old March 9th, 2009, 10:48 AM   #2
Hello Raul, as long as it seats flat and there is no clearence issues the tiny rotation is not an issue.
Double check focus wide open at corners and tell us how everything looks.
Steve Gerhart is offline   Reply With Quote
Old March 9th, 2009, 09:31 PM   #3
Hi Raul,
I am using the same configuration and know what you are talking about. I can't see any effect to this issue and I get excellent results with this adapter and Nikon lenses.
Cheers,
Ofer Levy Photography (no video clips on my site yet - a few more weeks)
Ofer Levy is offline   Reply With Quote
Old March 10th, 2009, 09:14 AM   #4
Hi Steve and Ofer, thanks for your replies!
I tested the tiny rotation for focus change, to see if the focus would be affected, but the tiny rotation does not appear to affect the image.
Obviously I won't be rotating the lens like that when shooting, but I've noticed how sensitive it is to any touch or move of the tripod and was wondering if this would be an issue down the line.
Well, now I can enjoy happy shooting and not worry about whether I should be returning any of my gear!
Thanks again for your replies and for helping a new member of the z7u-nikkon club!
Raul
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
