VCL-308BWH Wide-Angle Lens Hood & Filter - Page 3 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old April 6th, 2009, 03:58 PM   #31
Originally Posted by Derran Rootring View Post
Thanks for the footage Gabor!
I would really appreciate it if you would make some comparison footage of the two lenses in use. Perhaps (if it's not to much trouble) you can also show a bit of pan and tilt movements of the wide lens in use.
It has taken me a litlle more time than I expected. Her it is:
Sony Carl Zeiss Wide Angle Lens Test on Vimeo
Gabor Heeres is offline   Reply With Quote
Old April 7th, 2009, 02:09 AM   #32
Oops, it's been deleted from Vimeo, Gabor.
Derran - I'm pretty sure the Sony 0.8x designed for the Z1 won't fit the (same thread size) Z7. The Z7's zeiss lens is of a quite different construction to the Z1's.
Old April 7th, 2009, 03:29 AM   #33
Ah too bad the link isn't working anymore. I really wanted to see the footage. Thanks Gabor, for taking the time to make this vid for us. Hopefully you can get it back online.
Tom, I must have seen it wrong then. Didn't Sony make a wide converter for this camera?
Derran Rootring is offline   Reply With Quote
Old April 7th, 2009, 03:55 AM   #34
Yes, Sony make a 0.8x for the Z5 and the Z7 - it's just that I think they're different lenses and not interchangeable. Real users will know more.
Old April 7th, 2009, 04:01 AM   #35
Seond chance! If not in HD via Vimeo than back to SD:
Sony Wide Angle Lens Test Zideo, de grootste Nederlandse videosite waar je geld verdient met jouw video.
Old April 7th, 2009, 04:17 AM   #36
Yes fantastic! Thank you very much for this footage, really helpful. Looks like a great lens. This is the real wide view I was searching for.
Gabor, You use it on a S270 right? Do you ever take it off, or leave it on the cam the whole time?
Old April 7th, 2009, 04:26 AM   #37
Derran, yes, indeed I do use the version for the S270 which is slightly different from the Z7 version. It is my standard lens on the camera but so now and then I switch to the standard lens if I need more teleview. Both lenses are built with the same quality and optical there is no difference. Advantages of the standard lens compared to the wide angle lens: Longer zoomrange and barndoors on the front. The lenscap of the w/a lens drops off all the times. Every time I put the camera on the ground the lenscap drops of, quite frustrating.
Old April 7th, 2009, 05:55 AM   #38
Yes it can be very frustrating, if the lenscap keeps falling off. Too bad they didn't use the integral lens cap. Especially on a wide angle you want to keep the lens dust free. Otherwise it will be very noticeable on the screen.
Perhaps something like this will help you to protect the lens:
Century Precision Optics | DS-MBLC-00 Matte Box | 0DS-MBLC-00
Old April 10th, 2009, 05:46 PM   #39
I hope this helps. I bought a 16x9 WA lens for my Z7 and had to get the 16x9 rubber hood to go on it. I paid closer to $200 last year for it, but it seems to have had its price lowered. It doesn't close or have a cover, but does offer some protection. It slides over the lens and then you tighten it down a bit. It keep my fingers out of the shot as well ;)
16x9 Inc. :: Rubber Shade - 85mm
Chad Dyle is offline   Reply With Quote
Old April 20th, 2009, 05:18 AM   #40
Last week I was on an assignment covering a whaling ship returning to port with its controversial cargo. Decided to use the standard stock lens with protective filter as opposed to the wide-angle without a protective filter. Boy am I glad I did because the lens came into contact with ocean-spray and rain. I was constantly wiping it with a chamois. There was a lot of run-and-gunning going on and there were many chances that lens could have been scratched. Here's the bottom line for me: There must be a protective filter attached when I used the wide angle. Now, I just gotta find a solution. Any ideas?
Anthony Trotter is offline   Reply With Quote
Old April 20th, 2009, 05:28 AM   #41
Thanks for the suggestion, Chad. I will definitely look into the rubber hood. The lens hood that comes with the VCL-308BWH is very sturdy. Despite the lens cap falling off, it is very thick and provides a lot of protection. How’s the sturdiness of the 16X9 Inc. 85mm rubber shade that you linked to?
Old May 10th, 2009, 12:59 PM   #42
308BWH is good.
Sony VCL-308BWH Wide Angle Lens review part one (test) on Vimeo
This is my test video part one. but my English is poor. I can only speak Chinese. Sorry.
Chiayi Fun is offline   Reply With Quote
Old May 10th, 2009, 02:59 PM   #43
A very good alternative for the wide-angle lens is this wide-angle convertor from Sony: the VCL-HG0872K. Sony only markets it for the Z5, but it performs even better on the Z7, and it's a perfect fit. Plus no risk of dust getting into the cam in dusty working circumstances.
Originally, I was also looking at the VCL-308BWH, but for one third of the price I have a very good wide-angle solution (although there is some barrel distortion at the full wide setting), that comes with a mattebox and filter holder.
Old October 30th, 2011, 07:44 AM   #44
Re: VCL-308BWH Wide-Angle Lens Hood & Filter
I realize this is an old thread, but something happened that relates to it. I'd been going without a protective ND filter on the lens of my new EX1R because it was easier to screw on the wide angle converter when I needed it. Well, while shooting low to the ground from a moving car, a pebble was thrown and put a tiny scratch directly on the naked lens. A $2,000+ lens replacement could've been prevented with a $60 filter. Luckily, the cam is insured.
Old January 16th, 2012, 05:10 AM   #45
As to the filter: I've managed to screw a UV (HMC) filter from HOYA on to the lens and a lens hood as well. It took some strength to put lens hood back, but it worth it considering the las post.
Alexander Timanov is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
