#16 | |
I'm of the opinion that if you go to the trouble of carrying, storing and fitting a wide-angle then it should be good and powerful. When my aspherical adapter is on my Z1 I have a 17 mm to 132mm (equivalent) f/1.6 to f/2.2. (7.8x zoom). The 308BWH Sony lens is 24 - 192 mm, f/1.6 to f/2.4 as a reference (8x zoom). tom. |
#17 |
Thanks for the footage Gabor!
I would really appreciate it if you would make some comparison footage of the two lenses in use. Perhaps (if it's not to much trouble) you can also show a bit of pan and tilt movements of the wide lens in use. |
#18 |
Are you using a 35mm camera or a DSLR with a full frame chip? Because most DSLRs today are using chips smaller than the frame of a 35mm negative. Someone correct me if I'm wrong, but a 14mm lens on a Canon Rebel or Nikon D40 (budget DSLR) will have the same Field-of-View as as 21mm lens on my 1970s Minolta 35mm SRT-102.
#19 |
Zach, Nikon cameras with a DX sized image device are indeed a 1.5 FOV factor when compared to 35mm film. FYI Nikon D200's or D300's certainly can not be considered "budget DSLR's" even though they do use DX sized imagers. I am not a Canon guy, but I think some of their DSLR's were a 1.6 factor.
#20 | |
#21 | |
Stupid question: I had lots of problems with dust gathering on my Canon 5D's chip. I can imagine, when changing lenses on a Sony HVR-Z7 the problem is many times worse, given the small size of the chip. Do you clean the chip the same way I clean my 5D's? That is: with wet pads. |
#22 |
On the Z7, there is a prism that is exposed when you change lenses. The CMOS chips are not exposed at all.
#23 |
#24 |
On a camcorder a 3.5 mm (like the Fujinon 13x lens) or 3.3 mm (Sony VCL lens for the Z7) is really wide!
Sure, on a digital still camera you can go wider, but I wouldn't recommend it for a camcorder. Because you have to be able to make pan and tilt movements without to much wide distortion these lenses give on a digital still camera. I have a 12mm to 24mm on my photo camera and if I look through the eye piece and move the camera around it looks really weird. I don't want to record that on tape. But if you keep the camera still and take a photograph it looks great. It's also more expensive to get a nice wide angle lens for camcorders. I've worked with converters, but I don't like the barrel distortion you get from it... it looks cheap. I also have a digital (SD 4:3) camera with a Canon 4,4mm wide angle lens. And if you start working with such a lens, you don't want to use converters anymore. But unfortunately sometimes you have no choice. So that's why I'm interested in this lens for the Z7. If I want to go extreme wide I will get a fish eye lens. ;) Otherwise I want a good wide lens that will fit most filming situations that I can keep on the camera most of the time. |
#25 | |
If you do the same thing with a barrel distorting lens you lose this effect. Objects appear to move across the frame at a constant speed, but they grow larger in the middle as they barrel. And telegraph poles bend one way and then the other. But super-wides are often used in what I call 'frightening' situations, where people move room to room or run through mazes (The Shining). It's at times like these that the non-distorting super-wide really earns its keep. tom. |
#26 |
Yes absolutely.
Super wide is something you can't use for everything but their are moments you can really benefit from this effect. Also for a music shoot it can be useful. Same goes for a fish eye lens. You don't want to use it for your normal everyday shooting, but for action sports or music video's it can be a very useful effect. |
#27 |
Luc - I would use an air canister. Very carefully.
Still waiting for someone to post some direct comparison shots of the two lenses. High res stills would be appreciated - thanks in advance.
www.pfilm.co.uk |
#28 |
#29 | |
#30 |
Hi Luc. I don't have a Z7 yet, but hopefully I will own one soon. I now have two camera's and one is a Z1 (which I like to replace with the Z7). On the Z1 I use the 0.8x wide converter from Sony. It does gives a bit of barrel distortion.
I'm not sure, but I think that I've seen images of the Z7 with the Z1 wide converter mounted on the front. But perhaps someone else can confirm this. If this is indeed possible, I would recommend the Sony converter. I've also used a few Century Optics converters the last couple of years and although they are very well build, I probably wouldn't use them again. The barrel distortion was to noticeable for me. I shoot a lot of real estate, so I need to have a wide angle of view without too much distortion. But still, it's a good piece of glass and I know people that are very happy with it and never take it of their lens. |
