Z7U 35mm Lens Adapter & 1920x1080?
35mm ADAPTER: Anyone have any updates on where one can get a 1/3" to Nikon adapter for the Sony Z7U? Not looking for auto anything, just like to mount my Nikon Series E or newer Nikon lenses to the Z7.
1920x1080: Anyone heard of a hack or mod that gets 1920x1080 out of the Z7U? A friend of mine who is into "listening" to the market said there is a hack or mod that will provide this. I'm challenged to see how it could happen other than I heard that the imagers in this camera were in fact set up for 1920x1080 limiting the output of the camera to 20mbit (limits also of a 133x CF I think I read) and thus using a slightly faster CF the camera with the hack/mod could output to 24mbit, get the 1920x1080, and go to CF properly. My thinking on this latter is that it is an HDMI out to DV rack or something similiar that gave them a true HD. Anxious to hear if anyone else has heard this. |
Mike Tapa at MTF services makes a nikon mount and you can get them from e-bay:
Dont know about the hack to get full 1920x1080 in the camera but I do this re-size in final cut pro when I transcode to pro res 422 HQ 1920x1080i Here is a pic of my Z7 with the MTF mount and a nikkor 70-300mm ![]()
Over 15 minutes in Broadcast Film and TV production: http://www.imdb.com/name/nm1044352/ |
A little pricy huh? That's about $325 US. Whew. Work seemlessly? BTW, looks HOT! Want it!
Not as bad as the sony adaptor it is even more $$$
#5 |
#6 |
No problems with quality at all and the dof is actually too much on some lenses so I stop down a bit to f8 or 11 to improve this. There is a nice moon shot here taken at 300mm (X7=2100mm)
Untitled on Vimeo You can see some shots done with the 60mm micro lens here:Watch this Space on Vimeo ![]()
#7 |
Hi Rodger,
I also use the Mike Tapa's adapter and it is great. It won't effect picture quality as its just a ring with no glass. Have a look at this short clip - Z7E, Nikon 400mm f3.5 ED AIS from about 25 meters - the original is really nice and crisp with plenty detail and awesome DOF. Sony HVR Z7 wildlife clip on Vimeo Cheers, Ofer Levy Ofer Levy Nature Photographer |
#8 |
[QUOTE=Ofer Levy;933665] . . . Have a look at this short clip - Z7E, Nikon 400mm f3.5 ED AIS from about 25 meters - the original is really nice and crisp with plenty detail and awesome DOF.
Sony HVR Z7 wildlife clip on Vimeo Cheers, Ofer Levy . . .QUOTE] Nice, great DOF and images but YUCK on the subjects :o) Thanks |
#9 |
I hate to burst your bubble. But since that adapter is not mechanical the DOF is similar to the original 1/3 inch lens. Ovibously some of the those lens may have a higher f stop and have more DOF than the stock lens , but still not even close to 35 mm.
I really don't see the piont of putting these 35mm lens right on to the 1/3 sensor block. |
#10 |
To increase focal length, for things like nature shooting...300mm becomes something like 1500mm effectivley.
Chris J. Barcellos |
#11 | |
Thus, what I'm saying is that technically speaking there may not be an advantage but that doesn't mean that there isn't. I am looking forward to putting some big Nikon lenses on our Z7U. |
#12 |
Well ok I just assumed that we were goning for the whole cinema look.
#13 | |
just my opinion though. |
#14 |
i meant "that" cinema look.
#15 | |
I like the adapter & as you can see many people here are happy w/ it too. The biggest thing to remember is that you lose the handle on the lens so you can only hold the camera from the top handle when using a 35mm lens. Also from my experience the back focus is off (if someone knows of a fix for this, please post), but when I use a Nikon zoom lens, the focus changes as I zoom. Makes it harder to make sure everything is in focus. The biggest plus is: this adapter + used Nikon lens = $600 or so. New 1/3" video lens: $1,300-$10,000. I'd say that unless you already have a bunch of Nikon glass, look at the Sony mount. You might be able to use more features w/ that lens adapter. [QUOTE=Rodger Smith;9323211920x1080: Anyone heard of a hack or mod that gets 1920x1080 out of the Z7U? [/QUOTE] What I understand is that the censor isn't full 1920x1080, but the HDMI (and I'd assume even composite) is pre-HDV compression. So what you get is probably close to DVCPro HD, 4:2:2 100Mbps, similar to the HVX200 only should be a better picture since the Z7 has a higher rez on the chips. Now the "mod" (I wouldn't call it a hack since plugging in Video out isn't that tricky) you'll need to do is find some way to record the video. HDMI capture card is your cheapest option. A portable option would be to use the S270 SDI (or Z7 +SDI converter) and record to one of the portable hard drives that are being targeted at the EX1/EX3. |
