400mm Nikon manual lens??
Anybody have any insight or at least a good guess as to how a Nikon 400mm f/3.5 manual lens will behave on a Z7?? I am on the cusp of buying one, and wondered if any of you had an educated guess??
Thank you Jake |
It would be almost unworkably long without a very good tripod and support. On 1/3rd I tend to stop at 300mm and simply then improve my positioning on the subject. Also without any zoom actually finding your subject will be difficult to say the least.
That said some folks do use 400mm primes so with the right kit and patience they can work if you require big telephoto. |
#3 | |
I understand that the 7X factor will essentially give me 2800mm of zoom. How does that effect the light? Thank you Jake |
if I'm wrong about this, someone please correct me, but an f-stop is an f-stop
I don't think the X7 factor will change the light. stand alone light meters don't ask for legnth of lens, they only ask for ASA & f-stop. so if you're wondering about 3.5 being too dark for you on a 400mm lens, see if 3.5 is too dark on any lens you already have. but I have to agree w/ Mat Thompson in saying a 400mm fixed lens (ie no zoom) will be tough to find anything, though not impossible. I would think you might almost have to have a spotting scope added onto your camera to help "aim" |
#5 | |
I'm not familar with the Z7, but I'm using huge prime lenses with the Canon XLH1, both 300mm f/4.0 and 500mm f/4.5. In fact I prefer to do my footage in evening and morning light where the colors are more than beautiful and no hars lightning.
- Per Johan |
#6 | |
I ordered the lens today, so it should be here in a few days. When i get it, I will post some sample footage with the Nikon 400mm f/3.5 ASi-ED attached to the Z7. Thank you for the replies...please keep it coming. |
#7 | |
Check this out http://www.vimeo.com/1127928/l:transcoded_email Got this with the Z7 + Nikon 400 f3.5 ED AIS which I find it to be a SUPERB lens !!! It is difficult to find your subject but I am sure this can be solved with a small binocular mounted on it. |
#8 |
Ofer,
Approximately how far were you from your subjects (the bats)? And what were your ambient light conditions? Morning, mid-morning, mid-day, early afternoon,etc??? Thank you...your video gives me great confidence!!! Jake |
#9 |
Also...Ofer,
What support system do you use for this camera/lens set up? Do you have a photo you could share of this particular set up? Thanks Jake |
#10 |
Hi Jake,
I assume I was 20 meters or so from the bats. Keep in mind this is an effective 2800mm lens !!! This was taken in mid morning in a sunny day. The support system is a Vinten Vision 3 fluid head and Miller carbon fibres tripod. I attach the camera+lens combo to lens "leg" as the lens is far heavier than the camera body. I use a RedRock base with the quick release plate attached to the lens "leg". One thing to keep in mind is that with such long telephoto lens it is impossible (at least based on my short experience) to avoid vibrations when touching the camera/lens/handle. I can't really get clean, vibration free, camera movements. I have started to use a rubber band attached to the handle to reduce the vibrations while panning and it does help. Good luck and please share your experience with us. Cheers, Ofer Levy - Nature Photographer Sydney-Australia http://www.oferlevyphotography.com |
