capturing footage from a CF reader at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old June 25th, 2008, 06:50 AM   #1
Is there anyway in FCPS 2.0 I can capture clips from a CF reader and only have one or 2 long clips instead of a 100 small clips.
Jason LeFrense is offline   Reply With Quote
Old June 25th, 2008, 03:15 PM   #2
That would be a wonderful option. I keep thinking there has got to be a way to do that, but have not been able to figure out how.
Bruce Cleveland
Bruce G. Cleveland is offline   Reply With Quote
Old June 25th, 2008, 03:53 PM   #3
You mean that you'd like to combine many different takes into one long take?
It is easy to do in FCP but you have to be willing to lose your source TC.
I would just import them all (with log & transfer) then highlight all of them in the bin and drag them into a new sequence (they will go in alphabetically and hopefully chronologically.)
You can then export that sequence as a Quicktime reference movie (don't make self-contained) and throw it back in your bin to use as a source clip.
Tim Dashwood
Old June 25th, 2008, 04:49 PM   #4
Bruce Cleveland
download the Sony Recording Unit Utility.
http://pro.sony.com/bbsccms/ext/hdv/...DR60/soft.html
kdbf
Keith Forman is offline   Reply With Quote
Old June 25th, 2008, 05:38 PM   #5
"This software can only merge files that are divided by FAT32 specification."
Over 28 years watching TV
John Knight is offline   Reply With Quote
Old June 25th, 2008, 06:56 PM   #6
that's true but what is your point? The CF card is formatted to fat32.
kdbf
Old June 25th, 2008, 08:34 PM   #7
Jason wanted to know if there is a way to merge 100 small clips that have been individually created. The software only merges files that have been split because of the FAT32 limitations. It does not stitch or join smaller, un-split files into one big file - although I wish it would.
Old June 25th, 2008, 09:20 PM   #8
oh, you may be correct. I have never tried it with small files. Personally, I like the breaks between the clips. I find it easy to keep track with Vegas Pro.
You could just drop all the clips in the time line and then render it as one large clip and then delete all the small segments... I know with Vegas it will not re-render the clips so the quality remains the same.
kdbf
Old June 26th, 2008, 10:36 AM   #9
Hey Guys, thanks for the replies. I'm use to just capturing the one long clip and going though it setting ins and outs. Now that I have 90 clips in stead of just the one I find it takes more time to open each clip and view it then set an in and out point. I do like the fact that I can capture only the files I want, that makes it great for SDE. I have 2 weddings this weekend so I will let everyone know how things turn out.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
