Shooting with the Z7 and PD170 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old June 20th, 2008, 06:54 PM   #1
I plan on shooting a wedding with the Z7 tomorrow and the 170 for a second angle. My plan is to shoot 1080 30p on tape and DV edge cropped on CF. During post I will use the CF footage so I can match it with the 170. Later I will use the HDV footage for a highlight video of the wedding. Do you think this will work well or does anyone have a better solution.
Jason
Jason LeFrense is offline   Reply With Quote
Old June 20th, 2008, 07:31 PM   #2
Hi Jason,
I do the same thing except i use a Z1 and the 170 and it seems to work for SD @ 4.3.
Make sure you white balance both cameras to the same card under the same light as this will save you a lot of work in post.
I you can get a 16.9 lens adaptor for the 170 that would be best as this will give you wide screen from the 170 in SD without resolution loss, maybe you could hire one?
Simon
Old June 20th, 2008, 08:48 PM   #3
WTF would you want to do that for? see if someone you know has another HDV camera you can borrow. Hell, try and find an A1 and shoot it in 24f.
Scott Hayes is offline   Reply With Quote
Old June 21st, 2008, 05:08 AM   #4
Ya I'm thinking about selling the 170 and picking up a HV30 for backup. I figure I won't be using the 170 anymore and I still have the 370 if I need 4:3 SD.
Old June 21st, 2008, 05:12 AM   #5
I actually have a wide angle for the 170. Maybe I will use it and shoot in letterbox with the 170 to make it look closer to the 7Z. Any ideas on this working or not.
Old June 21st, 2008, 10:09 AM   #6
Jason
Jason I don't even know what to say. I have recently purchased a z7 and have 170s. I did mix the footage very well a couple of times now, but never with z7 shooting anything other than sd in 4:3. Anything else is going to look horrible.
Bruce
Bruce G. Cleveland is offline   Reply With Quote
Old June 21st, 2008, 02:24 PM   #7
Z7-pd170
Best option is to shoot in 4:3. In 16:9 You need an Anamorphic adapter for the PD170.
Zoltan Lorincz is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
