1080 24p from Adobe CS3 -> Camera at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old June 18th, 2008, 10:52 PM   #1
So, I shot some stuff on 1080i 24p and edited using Premiere CS3.... now I plugged the firewire back into the camera and "export to tape" except "export to tape" is greyed out and I can't use that function... anybody else experience this?
I've already changed all the settings on my Z7 "VCR" mode to HDV
K
Kevin Li is offline   Reply With Quote
Old June 18th, 2008, 11:09 PM   #2
you might have to enable it in Premiere
In CS2 and using Matrox RTX2/Premiere, if I want to export via DV-1394 I have to click on project, General, playback, and check export to tape, this should enable 1394 for export to tape
Bruce Reynolds is offline   Reply With Quote
Old June 19th, 2008, 12:20 PM   #3
I looked into that and it doesn't even recognized that I have a deck connected... maybe I should try re installing CS3
Old June 19th, 2008, 09:05 PM   #4
Figured it out, the "i.link set" menu option on the Z7 needs to be set to "off"
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
