Z7 Phantom power(attached Z7+Nikon 400 lens pic) at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old April 28th, 2008, 05:45 PM   #1
Hi all,
I am interested to use the Sennheiser MKH-416 mic with my Z7E. Do the XLR inputs provide Phantom power or I should get an external device for that?
Thanks!!
Sorry - can't figure out how to attach the photo - you can see it on my website under "NEW PHOTOS"
Ofer Levy - nature photographer
http://www.oferlevyphotography.com
Ofer Levy is offline   Reply With Quote
Old April 28th, 2008, 09:05 PM   #2
yes, the Z7 has phantom power.
Keith Forman is offline   Reply With Quote
Old April 28th, 2008, 10:34 PM   #3
Thanks for that Keith !!
Old April 29th, 2008, 11:32 AM   #4
Ofer, where did you find the adapter to attach Nikon glass to the Z7?
Winston Cutshall is offline   Reply With Quote
Old April 29th, 2008, 11:57 AM   #5
Ofer - If you want to use a 416 as an on camera mic, I found my 416 was too long to mount on the front clamp. You could maybe attach it to a mic holder on the rear hotshoe
edit - although looing at the lens you've put on it it shouldn't be a problem...
Mike Paterson is offline   Reply With Quote
Old April 29th, 2008, 03:44 PM   #6
Hi Winston - got the adapter from Mike Tapa - www.mtfservices.com.
Thanks Mike - I am going to use the mic on a tripod and not mounted on the camera.
Old April 29th, 2008, 06:22 PM   #7
Too right the 416 is way too good to be mounted on the camera, it is better used on a pole with the camera mic as a ambience mic.
BTW I have tested the new sony short shotgun mic supplied with the Z7 against the rode NTG1/2 on the camera and the supplied sony mic is way better and more sensitive and less noisy, add a wind jammer/cheater and it is really nice as it is not too long and I now use my NTG 1 on a short pole to get closer to the action.
Old April 30th, 2008, 06:09 AM   #8
Thanks for that Gary ! Any idea as to a good wind jammer/cheater for the Sony stock mic ?
Old April 30th, 2008, 06:20 AM   #9
As it happens I just got one delivered this morning from this guy:www.TheWindCutter.com
Good value and very well made.
I got mine off e-bay: http://cgi.ebay.co.uk/WindCutter-Fur...QQcmdZViewItem
The V1 mic is the same size as the Z7
Old April 30th, 2008, 07:37 AM   #10
That's really good to hear that the Sony stock mike is improved. The old mikes on the PD-150 through the V1 were essentially omnidirectional, or maybe a bit caridoid. Does the new mike have a narrower pick-up pattern? How do you think it would work if you detached it from the camera and put it on a boom?
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old April 30th, 2008, 08:43 AM   #11
Yes it is a lot better and has a nice tight sound but with a little bit more gain and less boominess than the rode ntg1. `It is certainly hyper cardioid and the back rejection is very good if you talk into the side of the mic it is virtually off.
I havent tried it on a boom yet but it may work well as it is quite directional and very small and light.
Old April 30th, 2008, 10:35 AM   #12
Ofer, I send to a return e-mail and by the way your pictures are superb!
I bought a nikon adaptor today and that big lens looks scary on the Z7 is it the 300 or 400mm? and what is the camera shake like?
Gary Nattrass is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
