Z7 Bayonet Mount at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
Old March 20th, 2008, 06:23 PM   #1
Z7 Bayonet Mount
Just wanted to restate that Sony using the same thread size of 72MM on the Z7 as the Z1 but having a different bayonet mount is total BUSH
Bruce Ostrout is offline   Reply With Quote
Old March 21st, 2008, 01:26 AM   #2
Yeah....I love how they'll tell you, and you can see when purchasing online, that lenses suited for the Z1U will fit the Z7U.....not the case. And, of course, they change things just enough to force purchasing yet more equipment. Some of the lenses are literally like 1/16th of an inch off.....ridiculous.
Marshall Levy is offline   Reply With Quote
Old March 29th, 2008, 01:22 AM   #3
Z7 Screw Ons
Need the WA guys - any solutions from Schneider yet? I'll even settle for a screw on that works.
Dave Williams
DVideography
Dave Williams is offline   Reply With Quote
Old March 29th, 2008, 08:43 AM   #4
As of this moment, you can buy any WA Lens that has a 72mm mount and it will work with the Z7U. Oh, you will also need some duck tape to make sure it doesn't fall off!
I can understand the whole new camera, new accessories concept, just make sure its all ready for us when the camera comes out :(
Chad Dyle is offline   Reply With Quote
Old March 31st, 2008, 09:37 AM   #5
Sponsor: Schneider Optics
Sony has yet again challenged us all. We are working hard on a solution but, as usual, it will require all new glass and mechanical design. I do not anticipate our usual line up of lenses for some time.
HOWEVER :) We do have this solution which will give you 30% wider performance and thread into the 72mm filter threads. You need the below linked item plus the adapter ring which is listed below but not on our website:
.7x wide angle adapter:
http://www.schneideroptics.com/ecomm...=1085&IID=1364
72mm Adapter Ring: 0FA-7x72-00 = $160.00
Ryan Avery
Schneider Optics
Ryan Avery is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-Z7 / HVR-S270
